B&M/Derale/other Transmission cooler with a fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Jan 22, 2014.
  1. Aug 9, 2018 at 6:32 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Do you have installed pics?
  2. Aug 9, 2018 at 9:08 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    TACOVRD[QUOTED] likes this.
  3. Aug 9, 2018 at 9:50 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    AR15xAR10[QUOTED] likes this.
  4. Aug 9, 2018 at 11:17 PM
    AR15xAR10
    Yup. Quite welcome.
    Mounted it to the AC condensor.
    Trans temps have risen over 200* one time since then, and weren’t there for more than 90 seconds. I used to hover between 185-230* now i hover between 135-175
  5. Aug 10, 2018 at 4:32 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    That’s really good info. When I was in WA state I’d only occasionally get over 200 but since moving to AZ, the triple digit heat has me more consistently over 200 and upwards of 230 which I’m not super comfortable with.
    Did you install yourself or have somebody do it? Did you have to fabricate mounting brackets?
  6. Aug 10, 2018 at 7:58 AM
    AR15xAR10
    Did it all myself. I could walk you through the entire process. I just haven’t made my write up yet. :oops:
  7. Aug 10, 2018 at 2:35 PM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    I would only rock one with a fan if it had a thermal switch on it. That way you won't have to monitor it all of the time and flip a switch when its getting "hot". If its just a daily driver and weekend warrior I would just go with a cooler without the fan. by using your existing heat exchanger and an aftermarket cooler you should be fine. Or are you doing lots of desert runs, towing or heavy stress on your tranny?
