B1650 scanned OR CODE 32 JUMPED (srs airbags)
Discussion in 'Technical Chat' started by GioLuque, Jun 20, 2012.
  1. Jun 20, 2012 at 9:15 PM
    GioLuque
    GioLuque [OP] New Member
    Giovanni
    Calexico
    SR5 TRD Off Road/Sport trim
    Camburg A-Arm
    This is described as occupant clasification malfunction. This problem should be indicating that you have a problem under the passenger seat/carpet
    problems may be one and/or all
    1. Ground wire
    2. Ocupant Clasification module (replace) not a common problem
    3. Short circuit in plugs (corrosion if those were exposed to humidity) most common problem (this happened to me)
    4. no.1 seat wiring problem (under driver side/carpet)
    5. ECU malfunction ( this is not common)
    But, how to know if you have this error code simply see a video in youtube
    http://www.youtube.com/watch?v=Pxs9Vdk4mGw
    In my case the air bag light blinked three times then waited for few seconds and bliked again two times, so this means error 32. Let say it blinks 3 times then waits and blinks 3 again, this means error 33.
    Go to and interpret the codes
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/047005.pdf
    then go to and see if you can fix the problem yourself as stealers do
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/047009.pdf
    At this time you may be able to know what problem your truck has. This diagram will test your skills, but all i can say is that to save you time just disconect the battery and wait at least a minute, then check all plugs under the front seats and make sure they are all connected, then disconect and check for corrosion in the plugs. If you find corrosion clean them gently, then reconnect them.
    You may need an OBDII scanner to clear the codes from the ECU, but sometimes you dont, just try to leave the vehicle with the battery disconected (only negative cable) for a long period of time (around 6 hrs) and then reconect it, if you are lucky you will not have to have an OBDII scaner to reset the airbags.
    I was lucky to fix this by myself and saved
    $200 diagnostic
    $300 labor
    $50 parts (they wont clean plugs)
    550 +tax
    I think the dealer was not very lucky to have me as:D client! Hope this helps
    Luque
  2. Dec 20, 2012 at 3:12 PM
    4x4 Taco
    4x4 Taco Off-road Enthusiast
    Pensacola
    4x4 TRD Sport DCLB
    Heated Leather Seats, Train Horn, Hood Struts
    Those links are dead, you wouldn't happen to have a copy of them still would you? I have an issue with my air bag light at the moment... but that's what happens when water gets in the cab.
  3. Aug 31, 2019 at 12:27 PM
    CaymanWest
    CaymanWest Member
    Cayman
    2005 Toyota Tacoma Red TRD Sport V6 Short Bed
    Pioneer AVH-4100NEX and rear-backup Camera
    For anyone having an airbag issue on a 2nd Gen Tacoma, this is the solution that worked for me that I documented here.
