Back of the truck sagging.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MichalK, Jun 28, 2020.
  1. Jun 28, 2020 at 5:28 AM
    MichalK
    MichalK [OP] Active Member
    Staten Island, NY
    19 Tacoma SR5, DC
    Prinsu Roofrack, RC side steps, LED lights, Diamondback bed cover, TRD wheels, Toyo AT3, AlphaRex
    Hi all!
    I have 2019 Tacoma SR5 4x4 5' bed.
    I know this topic was on this forum , but I haven't seen similar case as mine described.
    I'm a carpenter in NY I have all my tools on my truck every day, I don't take them off at all. Because of that back of my truck is lower than a front. I'm looking for a solution for that, I want my truck to look as level as possible. I was thinking about Sumosprings or maybe adding a helper leaf.
    Load on my truck is not crazy big , I say is somewhere around 300-400lb but it's clearly visible that the back is sagging, factory leafs look like there are kind of weak.
    Side note: not lift on my truck yet.
    What would You guys suggest me to do?
  2. Jun 28, 2020 at 5:37 AM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    02Duck likes this.
  3. Jun 28, 2020 at 5:38 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Factory springs are known to sag a bit. Your thoughts on either a helper leaf or Sumo springs is on the right track. I personally would go with the Sumos based on your payload but if you were to start hauling heavier loads then I would certainly consider helper leafs instead of the Sumos.
  4. Jun 28, 2020 at 5:39 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  5. Jun 28, 2020 at 5:39 AM
    Firk
    Firk Well-Known Member
    Firestone airbags are bad ass. I have them on mine and they are amazing
  6. Jun 28, 2020 at 5:39 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Welcome to the forum!
    For a daily load of 3-400lbs, I recommend upgrading the leaf pack!
    ExplorHer and kahanabob like this.
  7. Jun 28, 2020 at 5:42 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Welcome aboard! :wave:
    I think you'd be better off replacing the entire leaf pack - 400lbs of constant load will be a lot for an extra leaf to handle
    I run OME Dakars in the medium range - they are affordable and would handle your weight, but also tend to squeak if not kept clean and lubed and will rub on your stock shackle without modification.
    I don't have any experience with Sumo springs, but it's well known that when you use a Tacoma like a truck to haul stuff, the stock leaf packs have never been up to par.
    ExplorHer, kahanabob and Chunk like this.
  8. Jun 28, 2020 at 7:51 AM
    MichalK
    Staten Island, NY
    19 Tacoma SR5, DC
    Thank You Guys! More suggestions welcome :)
  9. Jun 28, 2020 at 8:02 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd wish my sr5 6' ac rear springs would sag a little...they now show the rear of the truck slightly higher than the front, and thats with a fairly heavy factory tonneau cover. It rides like a lumber wagon. You can really feel it over speed bumps compared to what the front springs absorb. My tundra was very compliant over the same bumps.
  10. Jun 28, 2020 at 9:32 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Like you I carry my tools pretty constantly but even empty other than the cap it’s way too soft for anything but driving around empty. I do carry varying weights though so I went the air bag route and have no regrets. If I knew I’d have a more constant bed load then Sumo’s or an AAL would be a simpler option since air bags need monitoring.
  11. Jun 28, 2020 at 10:06 AM
    zoo truck
    None
    Can't comprehend adding air bags or an extra leaf pack to carry 3-400 lbs of tools daily. Are we talking about the same generation rear leaf springs?
  12. Jun 28, 2020 at 11:16 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i agree
    used them on my 4door contractor taco
    they dont ride harsh
    are fully adjustable .....................seldom used more than 10psi to level out
    one could use a hand pump
    saves the rear end as the truck rides better
    bags damp out the usual concrete strips & minor potholes
    cost approx $250 + 2 hour install
    diy is straight foward ez
    good luck
  13. Jun 28, 2020 at 1:09 PM
    Wildchildjw04
    Wildchildjw04 Active Member
    2019 trd tacoma
    Second the a
    Firk[QUOTED] likes this.
  14. Jun 28, 2020 at 1:18 PM
    Chunk
    2016 DCSB OR
    Baby Ruth
  15. Jun 30, 2020 at 9:28 AM
    MichalK
    Staten Island, NY
    19 Tacoma SR5, DC
    I never heard of RAS before, looks interesting, might actually consider it.
    Thanks for all the help!
