Back seat latch rattle
Discussion in 'Audio & Video' started by Desert Snow, Apr 13, 2013.
  1. Apr 13, 2013 at 12:07 PM
    Desert Snow
    Desert Snow [OP] Well-Known Member
    Greg
    Chandler, AZ
    2012 4x4 DCSB Pyrite Mica
    Bilstein 5100s, 1" blocks rear, ATX Slot Chrome 17x8, Toyo Open Country 285/70/17s, Polished N-Fab steps, Pioneer AVH-P4400BH, Alpine PDX-V9, Boston Acoustics Pro60SE front, Boston Acoustics SR65 rear, ID 10D4v.3 sub, SuperCrew sub box, RaamAudio sound deadener, Escort 9500ix with BlendMount, shorty antenna, tint
    Have a DCSB with 10" sub behind the driver side rear seat. When the sub hits hard and the seat is latched it rattles. The rattle gets a little better when I push it hard against the back wall, but goes away completely when I pull the latch release and it just rests against the back. Definitely the rattle is coming from the latch.
    Anybody have this? How did you fix it?
  2. Apr 17, 2013 at 4:19 PM
    Aw9d
    Aw9d That one guy
    Can you adjust the latch that is in the seat? Maybe add more tension?
    if you don't plan on dropping the seat much, put insolite foam around everything that you can and close it. It will wear after time or if you pull the seats down a lot but will work for awhile.
  3. Apr 20, 2013 at 11:47 AM
    Desert Snow
    Greg
    Chandler, AZ
    Thanks. I put 2 layers of foam pipe insulation around the latch on the back wall so when the seat is closed it's tighter. It pushes the seat out just enough to keep the latch from rattling. So I turned up the gain on the sub...
    Still planning on getting together at Santan to compare systems. Just haven't had time.
