Back-Up Camera install???
Discussion in 'Audio & Video' started by dk6487, Feb 16, 2010.
  1. Feb 16, 2010 at 6:23 PM
    dk6487
    dk6487 [OP] NorCal Member
    David
    Novato, CA
    08 Silver 4X4 TRD Sport w/ Tow Pack
    Pioneer Z110BT Nav/DVD H.U., Sub Box by Mr. Marv w/ amp and 10" Sub, Rear-Leaf TSB, L.E.D. Guage Mod, 3" OME Lift Kit w/ 885, Total Chaos UCA's
    I Just received my Pop & Lock 8521 but it doesn't come with a handle. I have an 08 Dbl Cab and an aftermarket camera for it. Does this mean I have to drill a hole in my handle for the eye of the camera?:confused:
  2. Feb 16, 2010 at 6:31 PM
    dk6487
    David
    Novato, CA
    Maybe I should buy an 09 handle if it fits my truck?
  3. Feb 16, 2010 at 7:51 PM
    dk6487
    David
    Novato, CA
    No ideas?
  4. Feb 16, 2010 at 10:49 PM
    10.21 Well-Known Member
    Dillon
    North Carolina
    Black V6 Sport
    BHLM, Satoshi, Remove Mud Flaps, Debadge.
    I'd look for an alternative place to put the camera. Somewhere on the bumper maybe, or by the license plate. Just drill a hole if need be and maybe get a buddy who's good with iron works to make a mount. One way or another you'll probably have to do some cutting into the truck. Cutting on the bumper or near the license plate may be more concealable if you were to make a mistake (not saying you will). Beside that, your camera should of came with instructions as well as electronic layouts so it'll be easy as hell to wire. I'd just look for a simpler place to put. Cutting into the tailgate/latch itself could result in hitting an internal part that would end up costing you more (i.e. bars that hook the tailgate and disengage it).
    Too bad you don't live closer to me or vise versa man. I'd be down with selling you my 2010 tailgate for cheap with a trade on the camera. I plan on buying a tiregate and will most likely end up in your same situation in the near future.
  5. Feb 17, 2010 at 3:15 PM
    e-man
    e-man Active Member
    eric
    los angeles
    07 silver PreRunner 4x2 TRD Off-Road
    pop n lock 5300, aries 4" oval black step bar, oem cargo divider , pioneer avic z110bt nav unit, pioneer ndbc4 backup camera, - just starting out but more to come
    Yeah I think you have a good idea.....buy the 09 handle which has a place for a camera and just use the POPNLOCK in conjunction with it. I believe the toyota handle is available for just under $100 bucks.
  6. Feb 17, 2010 at 6:33 PM
    dk6487
    David
    Novato, CA
    Got off the phone with toyota today and found the damage to be $104 for a handle with the camera slot.
  7. Feb 18, 2010 at 6:45 PM
    dk6487
    David
    Novato, CA
    So my choice is buy a PnL 5300 and make a bracket or the toyota handle with the camera slot.
  8. May 8, 2010 at 10:46 AM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    5300 is a locking handle w/a camera slot. You shouldnt need a bracket as soon as your camera is the same size as the OEM.
  9. May 9, 2010 at 11:59 AM
    dk6487
    David
    Novato, CA
    I ended up getting the PL8521 and 2010 handle. A little black silicon and it came out perfectly.
  10. Sep 27, 2012 at 3:48 PM
    eqcmjhuff
    eqcmjhuff New Member
    john
    Gulfport MS
    2012tacoma access cab
    what is the color of the ignition on wire want to hookup monitor for backup camera ,have camera hook to backup light,works fine
