Back up camera protection
Discussion in '2nd Gen. Tacomas (2005-2015)' started by akhermit, Feb 24, 2013.
  1. Feb 27, 2013 at 10:55 AM
    #41
    dragnet
    dragnet Member
    2008 Indigo Blue Tacoma 4x4
    It seems like it'd be simpler to rig up a sprayer than a wiper. Many cars have tubing that runs from the washer fluid tank in the front to the back for the rear window wiper. Maybe rig it so the sprayer has a little force and can spray some washer fluid on the lens and clean it at your discretion?
  2. Feb 28, 2013 at 7:50 PM
    #42
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Haven't cleaned my truck in a whiiiiilleee and even ran her through mud, nothing's built up so bad that I've been out there to wipe off any considerable build up. I figure a sprayer would leave water on it like when it rains and one would see the droplets. A strong shot of compressed air would seem to work.
  3. Mar 1, 2013 at 7:49 AM
    #43
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I like the air idea.
    Lets see get $100 air compressor $60 air tank $50 for wiring, air lines and other parts.
    Then about 2-3 hours of work.
    Have it hooked up to a solenoid on a relay so when the truck in put in reverse it gives a 1 second burst of air.
    OR
    OR
    OR
    OR
    OR
    OR
    OR
    OR
    OR
    OR
    OR
    OR
    Just take finger before getting in truck and wipe lens.
  4. Mar 1, 2013 at 8:09 AM
    #44
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Finger wipe doesn't work if it's raining
  5. Mar 1, 2013 at 11:16 AM
    #45
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    You could just remove the camera and look behind you when you back up. If you decide to keep the camera, using your finger is the easiest, cheapest way to clean it. Or you can choose to garage your truck and never drive it in the rain, mud, snow, rain, fog. If you can wipe when you go to the bathroom then you can wipe the camera when you walk behind the truck after you're done driving.
    /thread
  6. Mar 1, 2013 at 11:27 AM
    #46
    OZ-T
    Peter North
    British Columbia
    x2
  7. Mar 1, 2013 at 11:29 AM
    #47
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    X3
  8. Mar 1, 2013 at 11:29 AM
    #48
    jtav2002
    Josh
    Reading, PA
    X4
  9. Mar 1, 2013 at 1:27 PM
    #49
    Kailey Jo
    Kailey Jo Well-Known Member
    Liam
    Ontario
    09 Access Cab TRD
    X5
  10. Mar 1, 2013 at 1:37 PM
    #50
    911tacoma
    911tacoma Well-Known Member
    Wendy
    Tennessee
    2022 DCSB 4x4
    TCSX Black out from dealer so far.
    TRUNK MONKEY!!!!
  11. Mar 1, 2013 at 6:22 PM
    #51
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  12. Mar 2, 2013 at 8:15 AM
    #52
    Utard
    Mark
    Nyssa, Oregon
  13. Mar 2, 2013 at 8:22 AM
    #53
    KenLyns
    Belly of the Beast
    Air isn't going to remove caked-on dirt. The only air would work is if you set it up to blast continuously, and have the air jet blast outward and shroud the camera lens (like how a TIG welding torch uses argon to shroud the tungsten).
  14. Mar 2, 2013 at 8:30 AM
    #54
    Kailey Jo
    Liam
    Ontario
    09 Access Cab TRD
    I disagree with this, military vehicles use blowers (compressed air) instead of wipers to clean episcopes (tiny little windows) A high pressure blast is going to take off anything that isn't bound to the top layer.
    In our application, if the lens cover is rain-x/waxed/whatever'd, any dirt may rest on the lens, but will not bind and will come off with the air, the same as a finger swipe.
  15. Mar 2, 2013 at 8:47 AM
    #55
    OZ-T
    Peter North
    British Columbia
    I don't care about dirt , I wipe that off when I leave for work
    I want to keep rain off it during travel so I can use the camera when I get to my destination
  16. Mar 2, 2013 at 9:09 AM
    #56
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    this will leave a little hazier overall picture, but
    you will be able to make out the scene...no water
    drops can possibly stick
    http://www.spillcontainment.com/everdry
    this is expensive stuff, so 'just testing the idea' is gonna hurt
  17. Mar 2, 2013 at 11:40 AM
    #57
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Makes me wonder how I manage w/o a backup camera.
  18. Mar 2, 2013 at 11:59 AM
    #58
    akhermit
    akhermit [OP] Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    I guess a washer system, and a wiper of some sort, OR a spray wash, with an air blast, which sounds even better. Thank you everyone for the ideas.:) Now I have to brainstorm and actually make something that will work, and be relatively inexpensive.;)
  19. Mar 2, 2013 at 2:57 PM
    #59
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    BINGO!
  20. Mar 2, 2013 at 3:30 PM
    #60
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    i think the basics of aerodynamics behind the truck will always cause dirt and liquid to build up on there in other than ideal driving conditions. I will agree w/ the above post, when all else fails, I turn my head...did it before I got this 2012 9 months ago, why can't I keep doing it. on a side note (and yes its my own doing) looking out at night through 5% put over factory tint makes things a little tricky, comes w/ the territory, you get better at it
