Back up camera to switch
Discussion in 'Audio & Video' started by mr2r6, Oct 29, 2011.
  1. Oct 29, 2011 at 6:46 PM
    mr2r6
    mr2r6 [OP] Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    I'm installing my backup camera and want to run it to a switch so I can turn it on anytime not just when it’s in reverse. My question is which wire should I hook the switch to get power or should I just hook it directly to the battery with a fuse?
  2. Jan 5, 2012 at 7:53 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
  3. Jan 5, 2012 at 8:00 PM
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    The negative wire. Or the wire that is coming off of the fuse box, if there is one. You would need one to come off the fuse box or an ignition source if said switch was illuminated.
    Make sense?
    Hope that helps!
