back up light opinion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myth01, Jan 20, 2011.
  1. Jan 20, 2011 at 5:46 PM
    myth01
    myth01 [OP] Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    so is it really worth tying in the aux back up lights to come on with the oe lights or just have a stand alone rocker in the cab? i know i can do both but is it worth it?
  2. Jan 20, 2011 at 5:54 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    if its not a problem doing
    i would rather have them hooked up to go on with the reverse lights
    unless you need them on while not moving.
  3. Jan 20, 2011 at 5:57 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    was thinking for night diving they might be nice to gear up
  4. Jan 20, 2011 at 6:02 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    its great and easy to just add them going on with the reverse lights as well...
    i put my relay inside the tail light wires..
  5. Jan 20, 2011 at 6:08 PM
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    Is there a switch that will allow you to do both? I would like to have them come on when I am in reverse, but I would also like a switch to turn them on when I am parked.
  6. Jan 20, 2011 at 6:14 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    SPDT or DPDT or in other words on/off/on
  7. Jan 20, 2011 at 6:14 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ive got mine hooked up separate from the oem reverse lights with a rocker in the cab figuring that they would overload the circuit. its a real luxury having the extra lighting back there especially with tinted windows.
  8. Jan 20, 2011 at 6:16 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    you have to install the switch......
    i put mine the easy way in my lil storage comp in the bed so i didnt have to run a wire into cab.."just cuz im lazy"
    then u tap into your power wire for stock reverse lights and put a rectifier diode on it then to the relay and your set...
    done the right way
  9. Jan 20, 2011 at 6:39 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I hooked mine up with the oem lights. You put the trucks in reverse and you have lights. Nothing to do extra, nothing to think about.
  10. Jan 20, 2011 at 7:17 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    No BU lights on the Taco yet, but had them on my last two trucks. Necessary for backing into those camping spots in the woods at night!
    The wife drove the truck one night, and inadvertently left the back-up lights on. She got pulled over, and almost got a ticket. I went to RadioShack and got a small buzzer/beeper speaker and wired it to the switch. A couple of wraps of electrical tape muted the beep to where it was audible but not at all annoying (it was behind the dash). Never had to worry about driving with the rear lights on by accident again! Yes, I had a lighted switch, the the better half didn't know what it was!!
  11. Jan 20, 2011 at 7:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    ^this
    wire the switch so that depending on position, your relay is activated by the factory reverse light circuit or the parking light circuit.
    I did mine that way, it's totally worth it. I can use the lights as work/loading/setup campsite lights without having the truck on or in gear, I don't forget to switch them off when driving out of a parking lot, and they go off automatically with parking lights in manual mode so I don't run battery down. This is the third truck I have done this on, wouldn't change a thing.
  12. Jan 21, 2011 at 8:43 AM
    myth01
    south sf, ca.
    08 taco Trd sport
    Hey brutal where did you get the diode?
    Joe if you have your parking lights on to use the aux back up lights, won't it kill your bat. Faster since you have more lights on than you need?
  13. Jan 23, 2011 at 3:47 PM
    [eric]
    [eric] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    I am thinking you can get them at Radio Shack for a few bucks.
    I understand hooking the DPDT up to the reverse lights or parking lights. I think this sounds great and would love to have on my truck. I am always afraid of hitting stuff when backing up at night.
    Is there a write-up or some photo's of the wiring or wire locations to do this? I am not a big electrical wiring guy, but I think I can pull this off as long as I find the right wires.
  14. Jan 23, 2011 at 3:57 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    On with the OE lights was easy! Just pop a tail light out, splice a line from the OE light to a relay, power from battery to relay to lights, lights grounded to frame. Switch in the cab involves running through firewall, fabricating another switch mount (or more expensive OE switch), and remembering to turn them off. Would be nice to have mine on while gearing up or working somewhere, but I can do that with the engine off, key to ON, and in reverse. Just have to make sure they're not on long enough to drain the battery.
  15. Jan 23, 2011 at 3:58 PM
    piercedtiger
    Jon
    Southern Tier, NY
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods-9.html#post62510
  16. Feb 24, 2011 at 7:07 PM
    erion109
    erion109 Well-Known Member
    Jayson
    Nashville
    06 TRD SPORT
    Weathertech FR & RR, DDM Tuning HID 55W 5000k Bi-Xenon, ARE topper, Yellow painted fog-lamp mod, anytime fog-lamp, Ipod interface, Red Top OPTIMA, Bilstein 5100s and 1.5 Toytech AAL, Redline Hoodstruts and EZdown tailgate.
    Could you provide some instruction on wiring the lights this way? I want them on my reverse lights, but would love to have a switch so that i can turn them on any time.
    Thanks!
  17. Feb 24, 2011 at 7:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yes, I suppose that the extra lights could kill the battery, but I rarely need them on with the truck off for more than a couple minutes.
    The truck is usually running when I have the lights on. If I had them wired to only turn on in reverse, I would have to shut my truck off and leave the trans in reverse with the ignition key on, then I would worry about killing the battery.
    I saw a news story recently about a guy who had wired his lights to come on in reverse. He was trying to load his truck at a self storage locker and left the automatic trans in reverse with the parking brake set. The brake failed and he was killed when the truck backed into him. If you would be at all tempted to leave it in reverse with the truck running, then for safety's sake PLEASE wire them to come on manually as well.
  18. Feb 24, 2011 at 7:25 PM
    brianh
    brianh Active Member
    Brian
    Shelby, N.C.
    06 Trd Sport , radiant red 4x4, sr5, 4.0 v6,
    Compustar remote start/alarm system, Infinity componets up front, JVC 3 ways in the back, 5" tvs in the headrests, JVC nav/dvd/i pod/ sd/ usb,back up camera (flush mounted in rear bumper), rear aux back up lights, LED bed lights, bestop camper cover, garage door remote operated by cig. lighter, katzkin leather kit(Ice Gray) with heated seats up front, (door panels too) All Mods installed by myself.
    I use mine all the time. I installed them after I put on the Bestop. It was a bit tough to see at night backing up. Adding these lights really help(while reversing) and it is very handy to be able to use them anytime. Just be sure to hook the circuit to a Ignition wire so you cant leave them on and kill your battery.
  19. Feb 24, 2011 at 7:37 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    How hard is the wiring job? I'm thinking of doing this in the future, but Im mr great at electronics/wiring etc
  20. Feb 24, 2011 at 7:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Easiest way is to buy a light kit that comes with a relay, follow the instructions and then install a different switch. I started from scratch on my truck. Here's what I did, sorry no pics.
    Run a fused wire from the battery, to the "30" terminal of a bosch type relay (very common and should come in most light kits). I used a twelve gauge wire to power my two 55 watt lights, it is probably slightly overkill, but I like overkill. My fuse is a 15amp. Relay is mounted under the hood.
    Run another length of twelve gauge wire from the "87" terminal to the rear of the trucks frame and connect to one wire from each of your lights. Ground the remaining wire of each light to the frame.
    That took care of the main power to the lights. The next step is the control wiring for the relay.
    I used a mini blade type "add a circuit" in the interior fuse block to tap the parking light circuit. You can choose any circuit you wish, but this makes the lights go off automatically if you forget about them. 16 gauge wire is easily sufficient for this. I used a five amp fuse for this wire, but I could have used a three amp if I had one. The relay should not need more than an amp to run it's coil. Run this wire to your switch location.
    Next, tap the reverse light circuit. On my 06, it was in the driver's kick panel. If I recall correctly, it's a red wire with a white stripe, I think it's 16 or 14 gauge. I installed an additional 5 amp inline fuse in this wire and ran it to the switch location.
    Now wire your switch. A single pole, double throw with center off works fine. They won't be lighted. You can wire a seperate pilot light if you wish. Connect the wire from the parking circuit to one of the outer terminals of the switch. Connect the wire from the reverse circuit to the other outer terminal. The center terminal is where you attach the wire that will be run through to the engine compartment. You could also power a pilot light from this terminal if wanted. Run your wire through the firewall to your relay. The wire needs connected to either the "86" or "85" terminal on the relay to power the relay coil. The remaining "86" or "85" terminal gets connected to a good ground.
    If you hooked it all up right, the center position of the switch should be off. Flicking the switch in either direction will result in lights on with factory reverse lights or with parking lights. I leave my switch in the factory light position all the time unless I need manual operation or for some reason want to disable the lights.
    Wish I was good at posting pics, or I would have taken some when I did all this.
