Backspace Needed for 35s on 17x9?
Discussion in 'Wheels & Tires' started by chris360hawks, Sep 16, 2011.
  1. Sep 16, 2011 at 7:06 AM
    chris360hawks
    chris360hawks [OP] Well-Known Member
    Helotes, TX
    98 4Runner 4x4 Limited S/C, Lifted, Locked
    My buddy has a 99' Tacoma with 3" Bilstein coil overs, 1" BL, and All Pro UCA's. He is stepping up to KM2's in size 35x12.5x17s. He is going to do a 17x9 Pro Comp Steel Wheel. I was trying to help him decide if he should go with a 4.5" or 3.5" backspace. He wants the tires to stick out past the fenders some. What size backspace should he run?
  2. Sep 16, 2011 at 7:07 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i dont know about the backspacing.... but he knows hes going to need to trim like crazy right?
  3. Sep 16, 2011 at 7:09 AM
    chris360hawks
    Helotes, TX
    He has already been running 315 all terrains and they rub minimally right now, but he is going to tub his wheel wells if necessary.
  4. Sep 16, 2011 at 7:17 AM
    97yota4wd
    Eric
    Mesa, AZ
    okay looks like you got it covered, i suck with wheels and stuff so i hope someone will chime in here
  5. Sep 16, 2011 at 10:51 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    3.5" is definitely the better choice of the two.
    4.5" is the stock backspacing for 1st gens.
  6. Sep 16, 2011 at 10:53 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    3.5". The more the better in this case...
  7. Sep 16, 2011 at 11:12 AM
    chris360hawks
    Helotes, TX
    Will 3.5" rub a shit ton on the wheel well without tubbing?
  8. Sep 16, 2011 at 11:22 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    yeah, I think the 3.5 is going to be the best. I've got 4" BS now with 35's (but with a 3" BL :() and I rub the frame rail when turned hard. Thats my main clearance issue. The truck came this way though, so until I can afford new wheels, i'm stuck with it.
  9. Sep 16, 2011 at 12:29 PM
    KPT
    09 Prerunner
    Probably. But a least it won't rub the UCA's like the 4.5's would.
  10. Sep 16, 2011 at 12:31 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    i have 4.75" backspacing and it fits fine with my 35's
  11. Sep 16, 2011 at 12:45 PM
    chris360hawks
    Helotes, TX
    Thanks guys. 3.5" it is.
  12. Sep 16, 2011 at 12:47 PM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    I have 3.75 on my walker Evans with 35s. Seems to be ok
  13. Sep 16, 2011 at 1:15 PM
    KPT
    09 Prerunner
    Bt you have a 6" lift and a 2nd gen. So your wheels stick out almost 2" more than stock. His will only stick out 1 more inch than stock.
    You also have a second gen. See above.
  14. Sep 16, 2011 at 1:17 PM
    PLC721
    Patrick
    Chandler, Az
    :facepalm:
  15. Sep 16, 2011 at 1:42 PM
    Brandon H
    Newhall, CA
    07 DC Offroad
    Wow!!! I have a 6 inch lift??? That's news to me!!!! Last time I checked I had icon remote resi coil overs on it! Am I going blind??? :rolleyes:
  16. Sep 17, 2011 at 6:33 AM
    KPT
    09 Prerunner
    I think you are going blind, because I said that nofords had a six inch lift, and that you had a second gen. Check again please.
    Completely different backspacing requirements for 1st vs. 2nd gens.
  17. Sep 17, 2011 at 2:17 PM
    Brandon H
    Newhall, CA
    07 DC Offroad
    I guess I am blind :rolleyes:
  18. Sep 17, 2011 at 4:41 PM
    Slodgetto
    Silas
    Dirty Terc
    :laugh:
