backspacing and offset of rims
Discussion in 'Wheels & Tires' started by gmarxen, Dec 29, 2011.
  1. Dec 29, 2011 at 7:24 PM
    gmarxen
    gmarxen [OP] Member
    Greg
    detroit lakes,mn
    04.tacoma,sr5
    I have a 2004 tacoma. I have a set of BFG all terrain 32x11.5 tires. I want to put them on a set of 15x8 rims with -19 offset and 3.7 backspacing. Can anyone tell me if I will have any trouble with rubbing on the mudflaps or anywhere else. my truck does not have a lift in it.
  2. Dec 29, 2011 at 10:19 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    i don't a have a definite answer, but i believe they're going to rub. at stock height, i was barely clearing with 265/70/17. the shallow negative offset isn't helping your cause either.
  3. Dec 30, 2011 at 5:56 PM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    On a first gen tacoma the backspacing is either +20 or + 25, I don't think the negative backspace is gonna help you. There's a dumbass on here complaning about his calipers rubbing, but he doesn't want to use spacers, doesn't want to grind the calipers, but buys wheels with negative backspace and bitches because they rub. Don't be like that dumbass
  4. Dec 30, 2011 at 6:33 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    A little harsh, but I do want to add that rubbing on the caliper has nothing to do with the wheels having a negative offset. It's more so the design of the spokes and/or mounting pad of the wheel. Too much negative offset and you're more prone to rub on the cab mount and/or front bumper depending on the tire size.
  5. Jan 5, 2012 at 10:51 AM
    gmarxen
    gmarxen [OP] Member
    Greg
    detroit lakes,mn
    04.tacoma,sr5
    thanks for your input. Sounds like I will have to lift the front end an inch or two to get this to work.
