backspacing help
Discussion in 'Wheels & Tires' started by johnw, Mar 19, 2010.
  1. Mar 19, 2010 at 3:01 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    17" x 9"
    [​IMG] 6x139.7
    [​IMG] [​IMG] -12mm
    XD7973
    [​IMG] [​IMG] 4.53
    GLOSS BLACK MACHINED
    [​IMG] [​IMG] XD79779068312N
    would these have enough BS or what BS should i get need some help. i got a lift already 2.5 billy's tsb AAL already have 285/70/17 on the truck
  2. Mar 19, 2010 at 3:02 PM
    johnw
    john
    orlando florida
    [​IMG] [​IMG] 17" x 9"
    [​IMG] 6x139.7
    [​IMG] [​IMG] -12mm
    XD7953
    [​IMG] [​IMG] 4.53
    GLOSS BLACK
    [​IMG] [​IMG] XD79579068312N
  3. Mar 20, 2010 at 1:16 PM
    johnw
    john
    orlando florida
    anybody?
  4. Mar 20, 2010 at 1:22 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Those look good. You want to stay around 4.5 BS for tires of that size. You still may have to trim some though.
  5. Mar 20, 2010 at 1:24 PM
    mr smitty
    mr smitty Well-Known Member
    Tennessee
    09 prerunner sport
    Westin Chrome running boards Rough Country 3" lift 17x9 motometal 951 chrome mickey thompson baja atz 285/70 17
    you will proly end up needing spacers
  6. Mar 22, 2010 at 6:27 PM
    johnw
    john
    orlando florida
    why will i need spacer?
  7. Mar 23, 2010 at 7:45 AM
    johnw
    john
    orlando florida
    know with them being 17x9 inches wide is that to wide. also i think im going with the bottom rims. look pretty sick to me. and whats the -12mm mean?
  8. Mar 23, 2010 at 9:56 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Either of those will be fine, you won't need any spacers. But you may have to trim the inner fender slightly.
  9. Mar 23, 2010 at 10:56 AM
    johnw
    john
    orlando florida
    already have. had the same setup besides lift when i was stock height
  10. Mar 23, 2010 at 11:15 AM
    johnw
    john
    orlando florida
    thanks mod for changing the title
  11. Mar 23, 2010 at 11:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    As TacoSupreem said you should be fine.
    The -12mm is the offset. The - puts the mounting surface closer to the hub which means more of the wheel will stick out away from the truck.
    https://www.rsracing.com/tech-wheel.html
  12. Mar 23, 2010 at 6:51 PM
    johnw
    john
    orlando florida
    thanks alot
  13. Mar 23, 2010 at 6:54 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    the max bs is about 4 3/4 in (4.75) those should clear.
