Backup camera anytime Mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Jan 5, 2017.
  1. Oct 22, 2017 at 10:03 AM
    #101
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    How hard to Pull the head unit out? limited 2017...
  2. Oct 22, 2017 at 11:48 AM
    #102
    tacotiko
    tacotiko New Member
    Very easy. Panel surrounding the head unit held in by clips. Pull from passenger side first. Then headunit is held in with 10mm bolts x4. I’m betting someone has a picture write up if you search it out.
    tomgru likes this.
  3. Oct 15, 2018 at 8:17 AM
    #103
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Great info, just finished this on my 2018
  4. Oct 17, 2018 at 6:08 AM
    #104
    blackoutt
    blackoutt @blackoutt_adv
    Southern IN
    Just ordered a harness from anytimebackupcamera.com to attempt this on the wifes rav4 with a ch4x4 switch. Anyone have any luck finding the illumination +/- to use on the switch backlighting?
  5. Oct 17, 2018 at 9:44 AM
    #105
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    It also helps if you're pulling a stump and need to take up slack in a chain, rope, etc. Sometimes when your help is calling out distance their internal tape measure is not 100% accurate.
    treimche likes this.
  6. Nov 5, 2019 at 8:46 AM
    #106
    Dcox
    Dcox Well-Known Member
    Dave
    Oregon
    2018 Tacoma Sport AC MT
    Grill swap, level, tires and wheels, bed lights, tailgate actuator
    Is there any way to do this mod without cutting the sensor wire? From what understand in this thread, I can ether wire a SPDT switch in the path of the wire or wire a diode in the sensor path and use a SPST switch. Either way, the sensor wire gets cut right? Is there a 3rd option that doesn't require cutting besides buying an expensive harness?
  7. Nov 5, 2019 at 10:19 AM
    #107
    Tacospike
    Two Trucks
    I bought my harness for like $30
  8. Nov 5, 2019 at 11:06 AM
    #108
    Dcox
    Dave
    Oregon
    Where did you get your harness? All I can find is a harness for a front and back camera that's north of $100.
  9. Nov 5, 2019 at 11:14 AM
    #109
    Tacospike
    Two Trucks
  10. Nov 5, 2019 at 12:13 PM
    #110
    Dcox
    Dave
    Oregon
    He is no longer selling them.. A wiring harness is easy enough to make though. Does anyone happen to know the part numbers for the male and female ends for the harness and maybe where to get them? The wires, coupler ends and a diode are cheap enough. I'd guess it would only cost like $10 for everything.
  11. Aug 16, 2022 at 4:06 PM
    #111
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Holy old thread batman.
    Has anyone hooked this up via a switch panel? I have recently acquired a rooftop tent and can't see bung out my rear window anymore. Was thinking of doing this via the switch panel.
  12. Aug 18, 2022 at 3:18 PM
    #112
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I’ve read through this whole thread and it’s left me more confused than when I began. I’m buying the anytime back up camera harness and using a CH4x4 switch. What’s all this about diodes? Do I need one? Does the anytime harness already have one? Please help me understand.
