backup camera help
Discussion in 'Technical Chat' started by brutalguyracing, Jun 28, 2012.
  1. Mar 28, 2013 at 10:05 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    It would be cool if it could somehow be attached to the center of the tire mount - so your view is looking out the center of the spare tire.
  2. Mar 28, 2013 at 11:16 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That would be pretty inconvenient IMO..
    I'm mounting my camera just above the license plate in the center of my swing out so I can easily back up to a trailer, or see how close I can get to something without my spare tire hitting it.
  3. Mar 28, 2013 at 7:38 PM
    JLink
    Josh
    Ocean, NJ
    got the new back up camera all wired up tonight.. took a lot longer than I anticipated.. tools were hiding and I fucked up my soft topper while backing into the garage with a floor jack in the bed with the handle sticking up.. hit the garage door and caved in the soft topper supports
  4. Mar 28, 2013 at 9:05 PM
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    Did you just splice the wires together? Anything special or just a cut a solder job?
  5. Mar 29, 2013 at 7:19 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Got pics of how it turned out? Probably better than my rush job... :(
    Sorry to hear about your soft topper. Reminds me of when i backed outta my garage and kept my drivers door open a little to look. Well the door caught my vice on the work bench and dented and chipped the paint on the edge. :mad:
  6. Mar 30, 2013 at 5:33 AM
    JLink
    Josh
    Ocean, NJ
    the camera has 2 rca cables, which when you skin them give you 2 wires and 2 shielding wires. I took the power in wire and shield (ground) and ran them to my tail light reverse light. since the bulb has power and ground wires I just carefully skinned and soldered my camera wires to them to give the camera power when I put the truck in reverse.
    then the other cable is the video out put and shield, which I had a buddy sit in my truck in reverse (with the truck just turned to on, not running) and tell me when I touched those wires to the correct wires on the stock camera wire harness. once I got that figured out i carefully skinned and soldered the new wires onto the old wires. this way if I ever need to get rid of the camera I can just cut the wires close to the solder and tape it up and be done.
    I dont but maybe I'll get a chance to take some today. what specifically would you like to see?
    Oh man that sounded bad while I was reading it.. I thought you were going to say you took the door off!
    Last night I needed to move the truck up a little bit so I could open the swing out in the garage, so I just put it in neutral and pushed it and figured it would roll slowly to a stop.. it kept going further than I wanted and I barely was able to squeeze in to hit the brake before the door hit the garage wall :eek:
  7. Mar 30, 2013 at 10:03 PM
    woods247
    back yonder
    Thanks for the info. I just relocated my factory camera today. I mounted it in the top/middle of my license plate so it would clear my swingaway. I used a 3/4" hole saw and drilled through the license plate and my CBI bumper. RTVd everything so hopefully it stays put. I doubt our police will care about drilling the plate since it's no more obstructive than an aftermarket camera/bracket combo. Works great and I had plenty of wire after disconnecting and removing it from the tailgate handle. Thanks for the motivation! I've been wanting to do this for over a year..
  8. Apr 9, 2013 at 8:21 AM
    DueNorth
    Sorry man, meant to respond earlier to your post. I was more wanting to see what camera you actually went with and did you hide the wiring in the swingarm itself? I really gotta get my hacky OEM camera out and install a nicer looking camera thats actually meant to mount on a flat surface.
    I can't count how many times i've almost rolled my truck into the wall of the garage myself! :eek: But lucky you were able to hop in and get on the brakes in time. A couple years ago when i had the stock bumper on still i decided to back the truck into the garage, its a tight fit for me but regardless i did it anyways. So i go to close the garage door and since the front bumper is actually sitting above the sensors, as the door is coming down all i hear is a huge scratching sound and the garage door is having an issue closing. Oh shit! It totally got caught on the bumper, scratching the living shit out of it. Fuck me! That's NOT buffing out. lol Nothing good comes from parking in tight garages.... At least now i have real bumpers on the truck. :)
  9. Mar 11, 2014 at 8:31 PM
    JLink
    Josh
    Ocean, NJ
    Lol x2 about small garages. Mine is too tight. (Sorry for the way late response)
    And I'm back at it again, broke the first camera so now I just ordered another and will have to go through this project again.
    I like the idea someone mentioned of mounting the Oem camera in the license plate but I have the good up license plate hiding my trailer hitch, so that wouldn't work :(
  10. Jan 21, 2018 at 4:52 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Bit of a bump maybe someone can help me.
    I have the stock harness and I’m trying to add a aftermarket camera. I was hoping to just connect the four wires from the old camera (red, white, blue and black) to the new wires in the aftermarket camera.
    The camera itself has these wires and this harness. Any help would be greatly appreciated
