backup camera help
Discussion in 'Technical Chat' started by brutalguyracing, Jun 28, 2012.
  1. Jun 28, 2012 at 11:02 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    ok im thinking about getting a plate rear bumper with swing out tire carrier....
    if i do that i will loose the function of my backup camera...and i love my backup camera......
    so i was looking for a solution for this problem.....
    was thinking about a license plate backup camera
    was wondering if anyone has done this or has any better ideas......
    if you have done this how did you tie it in to the existing rear view mirror screen....
    thanks
  2. Jun 28, 2012 at 11:05 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I'm in the same boat, so subbed for interest.
    I was thinking of having it mounted to the license plate frame, I've seen it done before and as far as I can tell it's the best permanent solution. I thought about maybe mounting it to the canopy but then I'd lose it when the canopy came off.
  3. Jun 28, 2012 at 3:53 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  4. Jun 28, 2012 at 3:56 PM
    Aw9d
    Aw9d That one guy
  5. Jun 28, 2012 at 4:00 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    do you really use it?
  6. Jun 28, 2012 at 4:05 PM
    Aw9d
    Aw9d That one guy
    The backup camera? I have the one built into my 2011 and I use it every single day. When the boss got a stupid Ford F350 I installed a license plate one and review mirror that had a monitor in it. Easy install, cheap, works great.
  7. Jun 28, 2012 at 4:06 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yes do you read much
    how did you tie it in with the existing rear view mirror screen
  8. Jun 28, 2012 at 4:28 PM
    Aw9d
    Aw9d That one guy
    The kit I got came with a review mirror that clipped on the stock mirror. It was from cosco for 200$ with license palate frame and mirror. Just need wire to power the camera and they supplied the cable for the picture.
    There was a post a few weeks back about someone tapping into the stock review mirror with an after market camera. If you search you should be able to find it.
    Other wise I'd see if you can take apart the camera, extend the wires and just fit it into a license plate frame. You could build one out of some fiberglass maybe?
  9. Jun 28, 2012 at 4:30 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :thumbsup:
  10. Jun 29, 2012 at 3:34 AM
    coffeesnob
    VA
    I just don't find it very useful. I wouldn't trust it if I thought something may be behind the truck just too small of a display and rounded too much.
  11. Jul 11, 2012 at 8:54 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I'm really missing my back up camera due to my spare tire gate as well. PM sent.
  12. Jul 11, 2012 at 9:04 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    SoCal - Fontana
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    The harness for the rear view camera is just above the interior glove box. iirc, its a 4 pin plug. I know it has a red and white wire in it but I don't remember the rest. You can strip down an RCA from your aftermarket camera and attach it that harness. It will work fine.
  13. Jul 12, 2012 at 6:18 AM
    DueNorth
    Could i not just splice into the harness in the tailgate instead of behind the glove box? Seems much easier. I'm an electrical noob tho so don't mind me... :eek:
  14. Jul 14, 2012 at 4:24 AM
    ProForce
    Anthony
    SoCal - Fontana
    Sorry I meant interior fuse box, not glove box. And Im not sure about splicing at the tailgate... iirc there is something different about they wiring there, but I could be wrong. You need to take off the tailgate cover and test each wire
  15. Jul 14, 2012 at 4:28 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    You ca pull the tailgate off and the wiring clip there is the wires for the backup camera.....and test them there.....I have the color codes I got from another thread on here...ill post them here when I can find them again
  16. Jul 14, 2012 at 5:01 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    The stock camera is 6v for some strange reason.
    Can't you move the stock camera to a new location?
  17. Jul 14, 2012 at 5:21 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
  18. Mar 28, 2013 at 6:30 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    So if I use the reverse light for the reverse signal, and ground the negative, that takes care of my 12+ and 12- for my new camera, then I have the yellow RCA cable that I need to tie into the stock wire harness. Just skin the RCA cable and solder it to the red video positive wire on the stock harness? Do I need to do anything with the shield in the RCA cable? Tie that into the blue wire on the stock harness or is it not necessary?
  19. Mar 28, 2013 at 8:02 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    just move the stock camera and mcgyver up a bracket for it
  20. Mar 28, 2013 at 9:29 AM
    JLink
    Josh
    Ocean, NJ
    Stock camera is in the tailgate handle. Way easier to buy a $15 back up camera and spend half an hour wiring it up... And have it not look dumb
