Backup camera switch / trigging reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, Apr 16, 2021.
  1. Apr 16, 2021 at 7:36 AM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I have my camera wired to my stereo that turns on the camera when the truck is put in reverse. Want to add a switch so I can click it to turn on the backup camera on.
    I'm assuming that when the truck is put in reverse that is what tirggers the camera to go on. So something is sending that signal to the cameral
    Is there a way to add a switch to trick the camera the truck is in reverse? Trying to locate the wire for it.
    Anyone do this? I've seen the kits, but I already have most of the work done can't imagine splicing a few wires onto a switch is that diffiicult and should save me about $180.
    Just need to know the location of the reverse wiring. Maybe bybass a relay with the switch linked to it to fool the camera.
  2. Apr 16, 2021 at 7:38 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Here is where I tapped into in my 2005 for a reverse trigger wire.
  3. Apr 16, 2021 at 7:44 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    What did you link that Red/White too to make the switch work?
    I found where the relay is located on the passenger side of the transmission.
  4. Apr 16, 2021 at 7:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was adding an aftermarket headunit so I needed a some sort of trigger to tell the HU that the truck was in reverse. I can just select in the HU to turn the camera on whenever I want.
    I realized after posting that this isn't exactly what you're looking for.
  5. Apr 16, 2021 at 8:28 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    It's close though. Just gotta find the wire that the relay uses.
  6. Apr 16, 2021 at 8:34 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Or actually how much power the relay uses and just tap something with the same power.
  7. Apr 16, 2021 at 8:36 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    I just tapped power and ground from the reverse light bulb in the back
  8. Apr 17, 2021 at 8:31 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    No one has added a switch to there camera?
  9. Apr 17, 2021 at 9:06 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no relay on the side of the transmission. That is the Park Neutral safety switch I assume that is what you are seeing there.
    I'm pretty sure there is a mod on here that says how to do the Camera on anytime. I'll see if I can find it.
  10. Apr 17, 2021 at 9:08 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  11. Apr 17, 2021 at 10:26 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I added a switch to my back up. You just need to add power to the input signal
    I even wired it to my Switch-Pro
  12. Apr 17, 2021 at 11:41 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Cool, yeah I figured all I need to do was add power to it.
  13. Apr 17, 2021 at 11:41 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
  14. Apr 17, 2021 at 11:47 AM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    You can add a switch but you will need a diode too. Otherwise the 12 volts will feedback and make the truck think it's in reverse when it is not. You get lots of colorful lights on your dash. Here is a schematic I made a while ago.
    Edit...you only need 1 diode. The second one in this drawing serves a different purpose. Ignore the one closest to the switch.
  15. Apr 17, 2021 at 12:14 PM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Thanks!
  16. Apr 18, 2021 at 9:39 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Is your camera a factory 6V or aftermatket 12V? If you have an aftermarket camera that uses 12V, it should not be that hard. Tap into radio switched Ignition 12V to a rocker switch, then to the camera. Bypass the current reverse trigger wire altogether. When you turn the switch on, it feeds power to the camera and the display turns on.
  17. Apr 18, 2021 at 2:55 PM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    It's the factory.
