Backup Sensor Install Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goufcustom, Jan 1, 2012.
  1. Jan 1, 2012 at 8:17 AM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    I am installing (will be later today) a set of backup sensors in my 2006 Tacoma and the control unit gets power from the reverse light wires, simple, but the control unit is supposed to be located in a "dry" spot, so under the bed is not a great location, I was going to locate the control unit behind the rear seats in my DC, and there is more than enough wire to do this, only problem is the power tap cable for the control unit is about 10" long, so it won't reach to the tail lights. Simple stupid fix is to just make theses wires longer, but the smarter fix would be to find the reverse light power cables in the cab, because they have to run up there, question is, were are they? I will keep looking, but I figure someone here has located theses wires before.
    I will try to do a write up on the install too. I have everything I need except the location of these wires so I don't have to run a long power cable back to the tail lights.
    THANKS
  2. Jan 1, 2012 at 9:08 AM
    goufcustom
    MD
    It looks like the wires run under the door sills on the drivers side of the truck, now to identify the wires...
  3. Jan 1, 2012 at 9:22 AM
    birdmanp
    birdmanp Active Member
    Justin
    Spartanburg, SC
    10 DC LB PreRunner TRD Sport - MGM
    Pioneer XAV3300BT w/double backup camera display, Skid Plate, Custom Homelink in dash
    It is a large red wire in the driver's side kick panel. Do a search and you should find it. I'll edit this post with a link if I find it real quick
  4. Jan 1, 2012 at 9:28 AM
    goufcustom
    MD
  5. Jan 1, 2012 at 9:52 AM
    birdmanp
    Justin
    Spartanburg, SC
  6. Jan 2, 2012 at 5:57 AM
    baldy54
    baldy54 Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    What type of backup system is it?? I want to put one in my 06 Tacoma. And where did you get it at?? Do you have pictures of the install?? I am interested in installiing one.
  7. Jan 2, 2012 at 11:03 AM
    ForNav
    ForNav New Member
    Nova Scotia
    2006 Tacoma Double Cab SR5
    Levelling Kit
    x2
  8. Jan 2, 2012 at 1:35 PM
    goufcustom
    MD
