Bad Center Carrier Bearing at 47k Miles??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gov875, Oct 29, 2012.
  1. Oct 29, 2012 at 3:09 PM
    gov875
    gov875 [OP] WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    I've been getting a ticking noise from the truck when driving, not when stopped, so i'm pretty sure it's something with the driveshaft and likely the center carrier bearing. I've only got 47k on the truck though isn't this a bit early to have that issue?
    Anyone else chime in with premature center carrier bearing failures? I saw people complaining about them but couldnt find much on mileage people had at the time.
    Thanks.
  2. Oct 29, 2012 at 3:16 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    that sounds more like a bad U joint to me...why don't you jack up one end at a time and slowing rotate your driveshafts while checking for play
  3. Oct 29, 2012 at 3:17 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    all the u-joints are tight as can be. lifted her up yesterday and messed with it.
  4. Oct 30, 2012 at 9:37 AM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    so despite there being no play in the joint the front one was siezed. it had thrown a lot of grease around so it was of concern but i couldnt get it to replicate anything while i was under there. Good call on the u joint though! 47k seemed awfully soon for it to go... maybe the 3" lift made it more likely to fail. $250 to replace all three back there today...
  5. Oct 30, 2012 at 12:24 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    how often have you been greasing them?
  6. Oct 30, 2012 at 7:01 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I didn't change my center bearing until 100k miles but hose sealed u-joints the PreRunners use are no good, you should get the Spicer replacement with zerks. Part # 5-213X, FWIW Spicer is the OEM for the driveshaft and u-joints.
  7. Oct 30, 2012 at 8:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My 2012 Prerunner has zerk fittings in all the U Joints...
  8. Oct 30, 2012 at 9:22 PM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    mine had zerks and i greased them at 30k. regreased the other day to see if it would solve the problem but it did nothing. the ujoint had a ton of grease thrown around undernearth the truck so it was busted. i'm having spicer's put in but i think the shop was recommending the sealed ones over the ones with zerks... thoughts?
  9. Oct 30, 2012 at 9:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would go with Zerk Fittings and grease them every other oil change unless you do a lot of water running then I would grease them every oil change. Water will wash out the bearings over time.
  10. Oct 30, 2012 at 10:24 PM
    badger
    badger Well-Known Member
    07 SR5
    30K is way too long between greasings. I grease mine every 5,000 miles. I have 82,000 hard miles on all original ujoints. Sealed ujoints are only better for people who would never grease them anyway.
  11. Oct 31, 2012 at 1:48 AM
    hetkind
    Howard
    Johnson City
    U-joints cycle when the rotate, hence the clicking noise. The carrier bearing would probably sieze or squeal...
    Having a degree in mechanical engineering comes in handy at times.
    Howard
  12. Oct 31, 2012 at 7:43 AM
    gov875
    Pacific Beach, CA
    TRD Sport DCLB
    Yea the noise was coming from the carrier bearing is all, the noise was transmitting down from the front u joint that far. Also it wasn't easy to get under there and listen that well since no one was around to help.
    Incidentally, i have a mechanical engineering degree.
    I was just following the maintenance manual on that one. Didn't have any problems the first 30 and i'm not even 20k into my last set of greasings. Guess the Toyota manual was a bit optimistic. Since they're putting in sealed ones i guess it'll save me worrying about it... until they go again. The rear two were entirely fine but i replaced all 3 so hopefully should eliminate the problem for quite a while to come.
