Bad Door Lock Actuators?
Discussion in 'Technical Chat' started by Blake, Jan 15, 2012.
  1. May 16, 2013 at 3:54 PM
    #61
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    I used to run electric R/C cars. Those motors where rebuildable until you toasted the armature, which are of similar design.
    How did the brushes look in yours? Did you take pics?
  2. May 16, 2013 at 5:40 PM
    #62
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Everything looked fine, I cleaned it out really well with CRC Electrical cleaner and put everything back together. I can take them back apart and take pictures if you think it'll come back to life. It will move the lever a bit, just won't actually cycle the lock. I took it apart a second time to make sure I had everything inside the actuator assembled correctly and nothing was catching. I also checked the cables to make sure they were moving freely within the casings.
    What's involved in a 'rebuild' of one of these electric motors? Better yet, do you know where I can find just a new motor with the correct output shaft?
  3. May 16, 2013 at 6:10 PM
    #63
    jandrews
    '09 FourDubDee TRD OR
    Glad I found this. My driver door unit shit the bed a couple weeks ago. I know what I'm doing this Saturday...
    Good news: Already have some contact cleaner, so no need to buy!
  4. May 16, 2013 at 7:55 PM
    #64
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    I meant to write down the number on the motor case and look for a source but forgot until after I had it back in the door.
    I didn't pay attention to how servicable the motor was when I had it apart.
    R/C motors are a bit more user friendly.
    http://www.youtube.com/watch?v=y8nCM9yuI-4
  5. May 17, 2013 at 5:26 AM
    #65
    Pugga
    Massachusetts
    Yeah, the Toyota motors are a more of a pain to service. The brushes on the actuator motor are like 1/4 the size of the ones in your video, they're tiny! When I get mine apart again, I'll get the part number on the motor. I did find a motor with the same part number, looked the same and everything, but the output shaft was different. The output shaft on the motor I bought was round, the one on the Toyota motor is a half circle so the screw gear will slide onto the shaft.
  6. May 28, 2013 at 2:38 PM
    #66
    kwade
    kwade Member
    kwade
    sc
    08 taco DC
    here
    Mine said
  7. Jun 20, 2013 at 5:52 PM
    #67
    V-TRAIN
    V-TRAIN Well-Known Member
    N. CACKALACKY
    08 TRD SPORT LONG BED
    DEMELLO ROCK CRUSHER SLIDERS, PIAA LIGHTS, TSB 4 LEAF PACK, CBI OFFROAD REAR BUMPER LINEXED, CBI OFFROAD FRONT BUMPER LINEXED, REAR 5100's, 1.5" TSB AAL, ICON EXTENDED TRAVEL COILOVERS @ 3", TOTAL CHAOS UCA's, HELLA MICRO DRIVING LIGHTS, IPOD INTERFACE, THULE ROOF RACK, UWS SLIM LINE BLACK TOOL BOX, 17" BBS RD TRUCK WHEELS, GOODYEAR WRANGLER DURATRAC IN 285/70/17
    ref. my rear ones went out tonight. sucks cause I take the kid to daycare and have to get back there alot.
  8. Jun 30, 2013 at 4:07 PM
    #68
    ktsmit
    ktsmit New Member
    08 PreRunner
    This was awesome! Just repaired both driver and passenger side actuators. The dealer quoted me $500/door to replace them! THANKS!
  9. Aug 4, 2013 at 1:24 PM
    #69
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    anyone have a picture of the inside of the rear actuators?
  10. Sep 2, 2013 at 12:45 PM
    #70
    two taco
    two taco Member
    Kansas
    2011 prerunner & 2006 sport 4x4
    Just finished passenger door on 06. Working great. Thanks for the info!
  11. Sep 22, 2013 at 9:21 AM
    #71
    Josh S
    Josh S Well-Known Member
    Josh
    Topanga, CA
    2016 Tacoma Limited 4X4 DC & 05 Tacoma 4X4 Double Cab
    05: Big Tires, Big Black Wheels, Leveled and raised a couple inches, Extra leaf in the back 16: Stock. For now.
    Great thread. Awesome site! Saved me a $1000.
  12. Dec 3, 2013 at 8:13 AM
    #72
    Networktcp
    Networktcp New Member
    I had this issue with my driver-side door last year and eventually found this thread. Opened the actuator as described and decided to test the motor before opening the motor itself. Removed the motor and attached it to a 9v battery. It spun freely. I put it back into the assembly and attached the 9v battery wires, switched polarity and again it worked in both directions.
    Reinstalled the actuator in the truck and it worked fine for the next 11 months.
    The problem resurfaced 2 months ago and last week it suddenly started working, first intermittently then constantly without any intervention ( I can still hear the motor struggle).
    Now the issue has surfaced on the driver rear door (intermittently).
    This leads me to question whether the motor is receiving 12v power or less (if my 9v worked without issue).
    Did the 9v power grind through the carbon buildup?
    Truly disappointing that I may eventually have to tear into the vapor barrier on all my doors.
  13. Dec 4, 2013 at 3:40 AM
    #73
    kwade
    kwade Member
    kwade
    sc
    08 taco DC
    My first guess was that under normal usage the motor is NOT on long enough to allow the brushes to sufficiently 'clean' the commutator bars.
    Eventually, the small amounts of comm-bar burning (carbon deposit) accumulates and the connection between brush and comm-bar is compromised.
    So much for using a motor where a simple solenoid would work!
    Yes, I would think so.
    The motor on-time with the 9v applied was enough to allow the brushes to 'scour' the carbon from the comm-bars.
    I tried to cut the soft-set adhesive, leaving a bit on the door and a bit on the barrier film and used it as a template for reattaching the barrier.
  14. Dec 4, 2013 at 1:46 PM
    #74
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    When I put mine back together, I must have put let some of the white levers in the housing slip. Now I have a door that can't "sense" when it's locked or not.
    Every time I close my door with the key in the ignition, the door does a double unlock. Also my lights only flash when the passenger door is unlocked, not the driver.
    Haven't felt like tearing it all back apart again to check. The worst part was getting into that housing without breaking anything. Wish someone who is good at it would post a good video on opening and closing the housing.
  15. Dec 12, 2013 at 2:59 PM
    #75
    AbunaiXR
    AbunaiXR Active Member
    Hawaii
    05 SWB Xrunner
    good thing i read this before buying those motors on ebay. what if you were to try and shave the shaft down to a half circle? possible?
    Also did you attempt to see if the motor itself worked granted you were somehow able to get the gear on?
    #75
  16. Dec 24, 2013 at 9:56 PM
    #76
    eskamo23
    eskamo23 Well-Known Member
    Pasadena, CA
    trd sport
    TRD cai with (AFE dry flow filter), de-flapped, tint, weathertech floor liners,coverking neoprene seat covers, rear TSB, Billy 5100's set at 1.75'', Pro Comp 7005's 17x8 BS4.5, any time fogs, tailgate theft mod, led lights in the int., slim cubby HID headlights and fogs, TRD skid plate, bed mat
    Well my drivers side front door actuator just went out on me. Only 48,000 miles on my 2010 taco. I also had my blower motor changed out 2 times by the dealer and the radio changed out once. I love my truck but these ticky tacky things are bs. I never had any problems with my 2003. I had 80k on that baby before I sold it. Thanks for all the info peeps have posted on this subject, I'll be looking into fixing this issue after Christmas! Merry Christmas everyone!
  17. Dec 25, 2013 at 9:23 AM
    #77
    kwade
    kwade Member
    kwade
    sc
    08 taco DC
    Sounds like the bean counters have conquered engineering!
    I cannot say that I dislike my taco, but I NEVER had any trouble (other than self-inflicted) with the other toyos that I have owned!
  18. Feb 3, 2014 at 12:45 PM
    #78
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Awesome. I just completed this project today on both passenger and driver doors and back in locking business with the remote door switch. Thanx to snektaco.
  19. Feb 3, 2014 at 12:56 PM
    #79
    medic2230
    Murph
    Bama! Roll Tide
    Haven't had this problem with the Taco but it happened on the 05 4runner. Toyota replaced all of the actuators and it was covered under the 100,000 mile warranty for $50 deductible. That was $800 saved.
  20. Feb 22, 2014 at 5:24 PM
    #80
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    I've got 25k miles on mine and just in the last 3 weeks the front drivers side door has been acting up. Thought it was remote so i swapped remotes and same thing. When i click the remote twice the rear doors lock with remote but not drivers door. But It sounds like it locks because I can hear it click just like the others. Also the dome light comes on right after i try to lock them with remote (i guess letting me know that the door isn't locked)? I think i should be able to get it taken care of under warranty.
