bad gas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Sep 5, 2008.
  1. Sep 5, 2008 at 2:08 PM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    Hey guys this is where I post about my 2001 toyota. Going to vent a little. We have a 2008 Honda Accord that has 6,000 miles on it. Wife filled up and got about 2 miles down road and car quit. Had it towed to dealership and they found water in the gas. Called service station and they said they just found out and would take care of it. Just got the car back and its still sputtering. They took the tank off and drove it 90 miles and its still sputtering. Man I hope this don't haunt us down the road. Rick
  2. Sep 5, 2008 at 2:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if i were you. i'd remove the fuel pump and clean it, reinstall it, and then use an addative in the gas tank, some thing that will dry up any water in the gas....you may need to use a couple of bottles of it. also, for the time being, i'd probably run a tank of premium(thats just me though), and a bottle of fuel system cleaner in the next tank. hopefully, it'll work and the injectors wont be messed up. the water drier should take care of it though. good luck!
  3. Sep 5, 2008 at 2:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    ^^ agree with above run a few cans of seafoam or the green alcohol in your next few tanks. Good luck.
  4. Sep 9, 2008 at 12:32 PM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    I had the same issue except the truck never made it off the pump and the station towed my truck drained and refilled plus gave me my $60 and I demanded a filter change at 65k I was going to change soon but for free I took advantage!
    Change the filter! It will hold the water! Should solve the whole issue!:cool:
