bad idle and no power?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 06yfz450ridr, Mar 16, 2012.
  1. Aug 21, 2012 at 10:04 AM
    #61
    BamaToy1997
    Bill
    Navarre, FL
    if it is adjustable, there will be a slightly ovaled hole on one of the mounting bolts for the TPS sensor.
  2. Aug 22, 2012 at 5:14 AM
    #62
    06yfz450ridr
    06yfz450ridr [OP] Well-Known Member
    Austin
    CT
    HID's
    yea thats what i looked for but there is none it just bolts on. kind of weird that you cant adjust it
  3. Aug 22, 2012 at 6:06 AM
    #63
    BamaToy1997
    Bill
    Navarre, FL
    Not every manufacturer has an adjustable TPS. Some go through an "idle learn" procedure where the computer will learn the TPS readings for idle and off-idle conditions.
  4. Sep 5, 2012 at 7:22 PM
    #64
    06yfz450ridr
    Austin
    CT
    HID's
    Hmmm just another thought before I just take this to Toyota or even ford where my dads friend manages to put a real scanner tool on here to check the a/f ratio etc. Could a crack in the manifold cause the o2 sensor to adjust the mixture richer if that's the cause. I know mine had a hair crack I saw It when I seafoamed it. it smoked pretty good from it. That's probably the main noise you hear under the hood. But the only thing about that is I did disconnect the o2 sensor and it didn't really run any better unless I have to disconnect both to check this theory.
  5. Dec 16, 2014 at 7:15 PM
    #65
    4banging4slanging
    4banging4slanging New Member
    99 Tacoma sr5 4x4 stock
    Bigger tires no lift
    Hey I have a similar problem I just don't know how to post a thread yet but my 99 Tacoma with the 2.7 is acting up went to start today wouldn't fire sat for a min looked at all the plug ins fine got back in fired right up then sprayed the motor clean and now it's got a rough idle and my buddy hooked his code reader up and it said egr, maf, misfire and fuel buddy said when his did that just a coil replaced the coil and still the same rough idle I give it gas and it Boggs down and when I let up on it a lil kinda cleans up Idk what is wrong with it any help please
  6. May 30, 2017 at 8:01 PM
    #66
    BrokeDad
    BrokeDad New Member
    1996 tacoma 4wd 2.7
    4in suspension lift and 3 inch body lift
    What happened did you ever find a fix. I have the same issue and done all the same tests. Im new here trying to keep 18 yr old daughters truck running.
