Bad Injectors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iltdi, Mar 26, 2019.
  1. Mar 26, 2019 at 6:42 PM
    #61
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Finally someone’s thinkin’ it thru!
    HacksawMark[QUOTED] likes this.
  2. Mar 26, 2019 at 6:44 PM
    #62
    Stocklocker
    17TRDORDCSBAT
    It seems so, but it never is. Dealers never lose money on trade-ins and it’s never a waste of their time. They will give you an honest boning whether you realize it or not. You might think it’s a wash price-wise, then they start with the transfer fees and depot clearance fees and market adjustments and warranty transfer fees.
    You will be boned. That you can count on.
  3. Mar 26, 2019 at 6:45 PM
    #63
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    $43 bucks to ship WTF?
    #63
  4. Mar 26, 2019 at 6:47 PM
    #64
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    That would be super extra duper weird.
  5. Mar 26, 2019 at 6:48 PM
    #65
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There are port injectors and direct injectors on the 3.5L. Wonder what 2 of his went bad. The direct injectors are the injectors that have the self cleaning feature. However they are the ones that are more expensive and also more time consuming to replace.
  6. Mar 26, 2019 at 6:50 PM
    #66
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Yeah prob so, I think trade in value on a 17 Trd is 23/25k
    Stocklocker[QUOTED] likes this.
  7. Mar 26, 2019 at 6:51 PM
    #67
    jaxyaks
    And they usually do
  8. Mar 26, 2019 at 6:51 PM
    #68
    iltdi
    iltdi [OP] Well-Known Member
    Rockford, IL
    2019 SR5 2.7 I4
    It was the two direct injectors
  9. Mar 26, 2019 at 6:53 PM
    #69
    Stocklocker
    17TRDORDCSBAT
    Did they give you an idea of the probable cause? Was it for sure fuel?
    BSFord likes this.
  10. Mar 26, 2019 at 6:54 PM
    #70
    jaxyaks
    It would be an expense but you might want to pull the others and see what your up against. IF and that’s an IF it’s gas that is causing it, they all have been exposed to the same gas. Just a thought and spitballing here. With those parts being so expensive it may be worth pulling them from a low mile wrecked one.
    HacksawMark likes this.
  11. Mar 26, 2019 at 6:55 PM
    #71
    fiftyxp
    When injectors go bad its hard to pinpoint a cause, but gas is usually the first thing you look at.
  12. Mar 26, 2019 at 6:58 PM
    #72
    iltdi
    Rockford, IL
    2019 SR5 2.7 I4
    Not really, they thought maybe gas.
    First they ever saw it
  13. Mar 26, 2019 at 8:20 PM
    #73
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    Everyone should understand that Costco buys gas as a commodity, but is the only top tier supplier to perform the final blending of the detergent additives at the fueling station when the trucks offload the fuel into the tanks.
    Other stations add the mixture at the truck loading dock to the tanker truck at the refineries terminal. If someone Is judging the gas that leaves the terminal to Costco, it isn’t done being blended yet.
  14. Mar 26, 2019 at 8:23 PM
    #74
    Stocklocker
    17TRDORDCSBAT
    Which means you actually have much less control. Get one wacko manager at one Costco, who’s had a few bong hits and either your get double the additive (having a bad trip) or no additive (society can suck it). I’d much prefer gas blended at the refinery, depot, whatever.
    BSFord likes this.
  15. Mar 26, 2019 at 8:26 PM
    #75
    Bryanccfshr
    Yes because truck Docks are models of integrity and diligent work ethic and the humans there are better then the humans at Costco?
    https://www.costco.com/kirkland-signature-gasoline.html
    Basicly human performance factors, be it in gas blending, or driving against opposing traffic on a two lane road are a fact of life. The consequences of error vary on the activity.
    xxTacocaTxx likes this.
  16. Mar 26, 2019 at 8:29 PM
    #76
    Stocklocker
    17TRDORDCSBAT
    Most likely. I’ve worked at both many times in my career and the quality control at a fuel depot compared to a retail outlet is not comparable. The Costco model is random at best.
  17. Mar 26, 2019 at 8:31 PM
    #77
    Stocklocker
    17TRDORDCSBAT
    That baffle-gab link from Costco you shared has some very clever hints in it. I’ll let you find the hidden ones, but the most obvious is “tested in THE lab” as opposed to “tested in OUR lab”. They really have no way of knowing what they are selling you.
    Reluctanse likes this.
  18. Mar 26, 2019 at 8:36 PM
    #78
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I doubt Costco has their own brand of fuel. Odds are they get it from a local supplier who follows their specifications. A lot of stations do this as well. Usually gas becomes bad due to some type of contamination once inside the tank. Anything with ethanol just sucks in as much water and moisture as it can. No station is fully immune to variables that can cause bad gas.
    Stocklocker likes this.
  19. Mar 26, 2019 at 8:37 PM
    #79
    Bryanccfshr
    Here is another issue I have with your line of thought.
    You highlight Costco and not the local retailer in the OPs fueling routine as a causal,factor without factual evidence . This is the kind of human factor we should be worried about. Biases can impact judgement and accuracy, even when evidence does not support the preferred conclusion.
  20. Mar 26, 2019 at 8:41 PM
    #80
    Bryanccfshr
    another issue to consider is station volume, if one batch is bad enough to ruin injectors, more local cases would be emerging. If that does not emerge the cause could be with the injectors and not the fuel bad runs run in manufacturing as well as fuel and oil blending.
    xxTacocaTxx and Stocklocker like this.
