Bad mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bmerr222, Mar 13, 2019.
  1. Mar 13, 2019 at 9:22 AM
    Bmerr222
    Bmerr222 [OP] Member
    Bryce
    2010 black Tacoma
    4 inch lift,33/12.50r18, muffler delete,etc
    I have a 2010 4.0l Tacoma trd. 4 inch lift 33s and muffler delete still has cats. I’m getting about 7 mpg I changed spark plugs but am wondering why my gas mileage is still so bad?
  2. Mar 13, 2019 at 9:23 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    2015 TRD Offroad
    Plus winter gas.
    Nunya Bizness likes this.
  3. Mar 13, 2019 at 9:25 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    Don’t think I have winter gas in my area
  4. Mar 13, 2019 at 9:26 AM
    tcjacado
    tcjacado Well-Known Member
    What tire pressure are you running on that lifted brick??
  5. Mar 13, 2019 at 9:27 AM
    Bmerr222
    Bryce
    2010 black Tacoma
  6. Mar 13, 2019 at 9:28 AM
    tcjacado
    Head winds prevalent in the area?
    You travel both ways up hill??
  7. Mar 13, 2019 at 9:29 AM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    Have you tried checking the blinker fluid? I know that can weigh the truck down quite a bit actually...
    If that doesn't work, I'd recommend doing an exhaust redirect. It helps your air intake and usually doubles MPG
  8. Mar 13, 2019 at 9:30 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    Not very windy but there are a good bit of hills in my area. Anyone think it could be o2 sensor or clogged cat?
  9. Mar 13, 2019 at 9:31 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    Blinker fluid in tact so aren’t my muffler barrings
    Amchuge, Benzdriver81 and MadDaddy like this.
  10. Mar 13, 2019 at 9:31 AM
    Ossaris
    Aliens
    SoCal
    You a lead-foot? If you're pushing that pedal down like a racecar, that may contribute to the issue...
  11. Mar 13, 2019 at 9:32 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    No I’ve been driving easy. Forgot to add it’s a 6 speed manual
  12. Mar 13, 2019 at 9:36 AM
    Gunshot-6A
    Conner
    Everett, WA
    2015 TRD Offroad
    Plus 4" lift and 33s. That doesn't shock me.
  13. Mar 13, 2019 at 9:38 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Have you done any other maintenance besides plugs. Like throttle body, maf, trans fluid drain and fill, injector cleaning etc?
  14. Mar 13, 2019 at 9:38 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    I don’t think it should be getting 6-7 mpg though
    frenchee and Sethhm0106 like this.
  15. Mar 13, 2019 at 9:40 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Also how many miles? 4x4 or 2wd?
  16. Mar 13, 2019 at 9:41 AM
    Nunya Bizness
    Do you have a truck full of trolls? Cuz they are quite heavy and WILL affect mpg.
    Gotta kick em out.
    Unchained 5150 likes this.
  17. Mar 13, 2019 at 9:41 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    I haven’t had the truck very long haven’t done any maintenance other than oil change and filter every 3k, plugs, air filter change I can’t thing of anything else off the top of my head
  18. Mar 13, 2019 at 9:42 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    100k 4x4 trd off-road package
  19. Mar 13, 2019 at 9:43 AM
    Bmerr222
    Bryce
    2010 black Tacoma
    Truck feels like it’s dragging more than it should also even with the lift and tires
  20. Mar 13, 2019 at 9:44 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I’d make sure your spark plugs are gapped correctly, just changing them to new ones may not help, or possibly make it worse if the gap is way off.
    I forget what the 1gr calls for as far as the spec though.
    My next guess would be one or two of the cats, and/or o2 sensors. Any of those gone bad can cause terrible mpg.
    The heaviest influence though is the right pedal, that said, 7mpg is worse than usual. I got 10mph while towing 4000lbs and have 4+” of lift and 33’s. I usually get around 14 mixed unloaded.
    Also, make sure you are compensating for your larger tires. Ie: 33’s are about 6% taller than oem tires. Let’s say you go 250miles on a tank of gas, 18 gallons used. [250+(250*6%)] / 18 will be your tire mpg.
