Bad Needle Bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sig45, Dec 5, 2018.
  1. Dec 5, 2018 at 4:29 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    My apologies, Yes....the Drivers Side.
    I was multitasking at work. I’m someone who doesn’t do that well. I should know better. Just came across your thread and thought I would chime in as I had the same problem about 3 years back and replaced the needle bearing with the ECGS fix.
    Sig45[QUOTED][OP] likes this.
  2. Dec 19, 2018 at 3:44 AM
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
  3. Dec 19, 2018 at 3:50 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Yes, also do the seal while you are there And make sure you use the gear oil as per their recommendations.
    4WDTrout and Sig45[QUOTED][OP] like this.
  4. Dec 19, 2018 at 4:46 AM
    Sig45
    Mark
    Maine
    So I've always used Amsoil severe gear 75w-90. That's what's generally recommended. I should go heavier per ECGS?
  5. Dec 19, 2018 at 4:52 AM
    hyper15125
    NJ (609)
  6. Dec 19, 2018 at 3:19 PM
    Sig45
    Mark
    Maine
    Stuff is THICK!
    Will this be an issue with sub-freezing winter temps here in Maine?
    FastEddy59 and 4WDTrout like this.
  7. Dec 19, 2018 at 3:34 PM
    hyper15125
    NJ (609)
    You can use the same stuff in 80 90 as per the website.
    The most important thing is to use the Lucas brand/type as it has additives so The fluid doesnt foam thus reducing lubrication to the bushing.
  8. Dec 19, 2018 at 3:35 PM
    Sig45
    Mark
    Maine
    Ahh...I may swap for the lighter version. Thanks.
  9. Dec 19, 2018 at 3:38 PM
    hyper15125
    NJ (609)
    I went with the 80 90 due to being in NJ
  10. Dec 19, 2018 at 3:39 PM
    Sig45
    Mark
    Maine
    My dealership (on the advice of my Tech) is going to install the ECGS bushing (I bought) under the front Diff warranty.
  11. Dec 19, 2018 at 3:40 PM
    hyper15125
    NJ (609)
    Perfect!
  12. Dec 19, 2018 at 3:51 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Yes. There are two(seals) depending on what you take apart. Every time I have to replace a cv axle, I replace both seals.
    This thread may be helpful: https://www.tacomaworld.com/threads/wheel-bearing-seal-and-cv-dust-seal-install-tip.460019/
    This.
  13. Dec 19, 2018 at 3:54 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Excellent!
    Just give the tech the 8” ECGS Bushing & drop the truck off. You’re good to go. I’d use the Lucus gear oil & weight ECGS recommends.
  14. Dec 19, 2018 at 4:01 PM
    Sig45
    Mark
    Maine
    Appointment is Thursday, 12/27. 2 days shy of my warranty expiring on front Diff. Bushing & new seal arrive Friday.
  15. Dec 19, 2018 at 4:04 PM
    #35
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :yes:
  16. Dec 19, 2018 at 4:07 PM
    #36
    Sig45
    Mark
    Maine
    I left my truck with them overnight with them one night this week. The tech took it for a drive first thing in the morning and heard/felt it. It's not terribly loud, but it's obvious. It stopped immediately when he put it in 4WD.
    :yes:
  17. Dec 19, 2018 at 5:27 PM
    #37
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    You’ll be glad you had the ECGS Bushing installed :thumbsup:
    Where in Maine are you?
    I have family in that state
    Sig45[OP] likes this.
  18. Dec 20, 2018 at 3:29 AM
    #38
    Sig45
    Mark
    Maine
    Southern Maine. Just one town over from Portland.
  19. Dec 20, 2018 at 5:52 PM
    #39
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Oh, ok. I have Family in Trenton & Waterville.
  20. Dec 20, 2018 at 5:54 PM
    #40
    Sig45
    Mark
    Maine
    Just a quick 45 minute drive up I 95.
