bad passenger side lean
Discussion in 'Suspension' started by kbauman92, Oct 20, 2012.
  1. Oct 20, 2012 at 10:27 PM
    kbauman92
    kbauman92 [OP] Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    i just checked the c-clip and it seems to be still perfect, the crazy thing is it drove fine from WA to Montana today besides a little alignment issue.
  2. Oct 20, 2012 at 10:30 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I can see the coil seat in the picture and the welds (black spot under the coil).... Besides, if your coil seat was broken....that coil would be dangling there and your truck would be leaning MUCH worse than that! That coil seat holds the entire front suspension up....
  3. Oct 20, 2012 at 10:34 PM
    Janster
    Jandy
    Lancaster, PA
    Don't always focus on the 'low side' - Something could have happened to the 'high' side causing it to force the other end of the truck downward.
  4. Oct 20, 2012 at 10:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Check this on the driver's side OP ^^
  5. Oct 20, 2012 at 10:34 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Is it even the passenger side is low? Or is your driver side higher than it should be?
    I guess I'm the slow one... Drr
  6. Oct 20, 2012 at 10:35 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    try putting a jack on the pass side and jacking it up, maybe something just needs to go back into position. :notsure:
  7. Oct 20, 2012 at 10:37 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    the drivers side is the right height but its worth a shot, how would i unfreeze the shackles if they are frozen
  8. Oct 20, 2012 at 10:38 PM
    OZ-T
    Peter North
    British Columbia
    Compare the two sides , are they in similar positions ?
  9. Oct 20, 2012 at 10:39 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The truck looks like its leaning towards the passenger side front end. Gotta be something to do with the coil.. OP, if you can try to put a jack under the front end, take the tire off and post a picture on here.
  10. Oct 20, 2012 at 10:44 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    the shackles are really similar, not enough to cause this
  11. Oct 20, 2012 at 10:46 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    I can do that once i get a hold of a jack, im at college i have all the tools besides a jack. I reached out to the Montana tacos hopefully someone could be kind enough to let me use one for a few hours
  12. Oct 20, 2012 at 10:48 PM
    OZ-T
    Peter North
    British Columbia
    Yeah you dumb shits
  13. Oct 20, 2012 at 10:52 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    Haha, Possibly the blinker fluid?:notsure:
    There set @ 0 with the eibach coils
  14. Oct 20, 2012 at 10:52 PM
    krimson
    krimson Nothin
    TRD Off Road
    Sounds good :thumbsup:
  15. Oct 20, 2012 at 10:55 PM
    #35
    Janster
    Jandy
    Lancaster, PA
    Not necessarily....I've had situations where the Pass side rear was high causing the drivers side front to pitch downward. Can't always assume its the low side.
  16. Oct 20, 2012 at 10:56 PM
    #36
    OZ-T
    Peter North
    British Columbia
    OP has stated the shackles aren't out of normal alignment though , no ?
  17. Oct 20, 2012 at 10:58 PM
    #37
    krimson
    krimson Nothin
    TRD Off Road
    :notsure:
  18. Oct 20, 2012 at 11:00 PM
    #38
    krimson
    krimson Nothin
    TRD Off Road
    Yeah, the picture of the front end isn't really showing anything in detail... Hence why throwing all the possibilities of what's causing this till we get a better picture..
  19. Oct 20, 2012 at 11:04 PM
    #39
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    yeah sorry guys, its dark and all i have is a iphone i can try and take better ones in the morning
  20. Oct 20, 2012 at 11:06 PM
    #40
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    there isnt anything out of the ordinary but ill go out tomorrow and try to get better pics and more angles of the front and rear
