bad rear suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rezu, Mar 9, 2013.
  1. Mar 9, 2013 at 7:57 AM
    Rezu
    Rezu [OP] New Member
    Dave
    Wisconsin
    Stock
    I need to know the best way to stop my o5 tacoma 4door from bottoming out on every bump.
  2. Mar 9, 2013 at 8:00 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Since you are no longer eligible for the TSB leaf springs you will need to get new stronger leaf springs or add-a-leaf.
    Search AAL.
  3. Mar 9, 2013 at 8:17 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    Check out wheelers off road, they have 4 different aal sets, two of which are three leaf progressive so they don't hurt ride as bad, I'm getting the 3leaf progressive hd when I can afford it since my dealer won't do the tsb for me...
  4. Mar 9, 2013 at 8:17 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I don't recommend an AAL if the springs are already shot. Get new springs and new shocks... it's a pretty simply solution.
    Edit:
  5. Mar 9, 2013 at 8:20 AM
    acdronin
    acdronin Well-Known Member
    If you can't afford all new springs, then AAL are a cheaper way to go, do you regularly haul loads or have a shell in the back?
  6. Mar 9, 2013 at 9:44 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Firestone RideRites, easy self install, effective and a good value.
