Bad Ticking Under Accel When Cold - Normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Nov 28, 2010.
  1. Nov 28, 2010 at 3:31 PM
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Our 2010 Tacoma purchased in June has developed a bad lifter-style tick. It ticks when its started cold and driven, and ticks steadily until its completely up to operating temp.
    It's not an exhaust leak, it's coming from under valve cover.
    Normal cold engine tick, or something else?
    Truck has 650 miles on it.
    4 cyl motor.
  2. Nov 28, 2010 at 3:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have the dealer check it out.
  3. Nov 28, 2010 at 4:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Best to have it checked out so at least it's documented. My V6 does it too, seems to be worse now that the weather has turned colder.
  4. Nov 28, 2010 at 4:10 PM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    Don't know about your 4 but my V6 always ticks worse when cold though.
