Bad to downshift in auto?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MontanaTaco, Oct 9, 2010.
  1. Jul 3, 2012 at 7:31 PM
    #61
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    yea.. that must be what 2 degrees..LMAO.. it is not substantial enough to worry about..
  2. Jul 3, 2012 at 7:36 PM
    #62
    Blygy
    East of Edson
    Yea.. But if you think about it.. you have high air flow through the rad due to the speed.. No fuel going to the cylinders because your foot is off the throttle. High coolant flow due to the increased RPM.. Everything there points to cooling not heating..
    I was just wondering what the thought process was.
  3. Jul 3, 2012 at 7:51 PM
    #63
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    As long as this tread has been revived, my 2¢...
    Under normal driving conditions with auto transmission, I really don't feel it's necessary to downshift to engine break...in fact, I found the 2nd Tacoma auto to be surprising good at doing this on it's own (some may feel it's too good).
    If, however, you're going down a prolonged steep decline, it certainly is a good idea to gear down and engine brake as required.
  4. Jul 3, 2012 at 8:22 PM
    #64
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Yes friction is so insignificant.
  5. Jul 3, 2012 at 9:08 PM
    #65
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I will downshift to prevent standing on the brakes to hard. If you have ever driven a stick shift, you should be aware of the shift patterns and use the trans to break the engine imparting only the force needed to assist otherwise normal breaking. In other words, when you find you going to smash the breaks, use the trans to provide enging breaking suficient to allow normal breaking pressure, without exceeding the rev bandwith of any specific gear. Thats how I roll.
  6. Jul 3, 2012 at 9:47 PM
    #66
    Syncros
    Syncros Well-Known Member
    Something interesting I noticed about my Tacoma is the computer prevents the truck from over-revving on a downshift. It will wait until the truck is traveling slow enough(lower rpm) and then downshift. I noticed it first in 4wd low, shifting from 2 to L, but have since duplicated it in 2wd at higher speed.
    Now im not sure if all automatic Tacoma's are programmed this way so I am in no way responsible for your actions/damage to your truck if you try this. Coming from owning only standard transmission vehicles up until now I find myself down shifting every time I drive the truck.
  7. Jul 3, 2012 at 9:55 PM
    #67
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I down shift all the time. My tach routinely goes into 4000 RPM when downshifting. I've never seen my temp gauge go up at all, nor does the engine seem any hotter under the hood as compared to when I didn't down shift. The downside is that it's eating up my rear tires much faster due too them taking the brunt of the braking action.
  8. Jul 3, 2012 at 9:58 PM
    #68
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's fine
  9. Jul 3, 2012 at 9:59 PM
    #69
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    i down sift to remind me how much fun my manual was before i got a auto.[​IMG]
  10. Jul 3, 2012 at 11:27 PM
    #70
    PaintDrinkingPete
    NoVA
    But it's really not the same now, is it?
  11. Jul 3, 2012 at 11:35 PM
    #71
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I never had heard of people even shifting while they're moving in autos. Then again, I'm not familiar with their workings. What are the limitations on it? I'm guessing Drive-3-2-1-N are able to be shifted in to when you're moving?
  12. Jul 4, 2012 at 5:17 AM
    #72
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    When you touch the brakes the lockup disengages the trans does not down shift.
  13. Jul 4, 2012 at 6:39 AM
    #73
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Depending on the grade, it will in fact downshift. Mines gone as low as 3rd.
  14. Jul 4, 2012 at 1:58 PM
    #74
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    no :pout:
