Bad valves suspected
Discussion in '1st Gen. Tacomas (1995-2004)' started by 123DABTACOMA, Apr 24, 2015.
  1. Apr 24, 2015 at 5:06 AM
    123DABTACOMA
    123DABTACOMA [OP] Little DAB
    Dave
    Missouri
    1999 Toyota Tacoma SR5
    3inch lift
    Morning Folks , Bought my first Tacoma a month ago . Its a 1999 SR5 4x4 with the 2.7 automatic with 270,000 on it . Upon trying to troubleshoot the engine misses and trouble codes , I bit the bullet and did the compression check . Sure enough problems . I'm not sure my tester was working properly ,but worked well enough to know #1 has the biggest problem . Needle barely came up at all ,then right back down . wet or dry didn't matter . The other three came up to 150 to 160 , wet or dry didn't matter , then went right back down .
    I then did a leak down on #1 with straight shop air and heard the air escaping through the exhaust . At this point , I don't know if I should start looking for another engine or pull this apart to see what I may find . My thought is , Cant put a new head on a block with 270,000 . Might be the cams or the valves , any suggestions ??? Thanks Little DAB
  2. Apr 24, 2015 at 8:18 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Pull the head, clean and inspect. Verify that the suspect valve is leaking. If yes, take the head to a engine machine shop. http://www.crankshaftco.com/engine-repair-directory/missouri.html Have them check all the valves and their seats for damage or excessive wear. If damage or excessive wear is noticed, have them grind the all valves (intake and exhaust) and and all their seats and verify seal. Usually when one valve is bad, the others are not far behind. The shop should be able to do all this in a day.
  3. Apr 24, 2015 at 8:40 AM
    123DABTACOMA
    Dave
    Missouri
    3inch lift
    Thanks so much for that list and advice, Will the machine shop be able to shim valves to spec. ? 270,000 miles will that cause problems in lower end ?
    Thanks again
  4. Apr 24, 2015 at 9:34 AM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Just wondering but are you going to try and adjust the valves first before removing the head and possibly doing unnecessary work? If your truck has always missed/stumbled then chances are its been driven that way long enough to cause damage by the previous owner. If thats the case then disregard my comment lol. However if it just started doing this id adjust the vlaves first.
  5. Apr 24, 2015 at 10:32 AM
    CD20H
    Ben
    North Texas
    This it true. I state the more drastic solution. 043rz is correct. Adjust the valve first, then if you can't get a good compression number, continue on with what I suggested.
    About the engine machine shops capability to shim the valves to spec. Yes they can.
  6. Apr 24, 2015 at 3:09 PM
    123DABTACOMA
    Dave
    Missouri
    3inch lift
    Thanks You guys . Think I will trade it in , already out of Time , Money and Patients . Lol
  7. Apr 26, 2015 at 11:09 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    well they will need to all be done since the head rework will change all the clearances. this job is not hard and even easier with the head off and just requires a feeler gage check
    if it still runs ok trade it in and get something that doesn't need work would be your best option. if you start getting into this it could become a money pit if you find other problems and cant do your own mechanic work
  8. Apr 27, 2015 at 2:15 PM
    123DABTACOMA
    Dave
    Missouri
    3inch lift
    I take it the guy I bought it from had been driving like this for a while . Although I like the truck and only have $4000 in it , I just bought his problems . I believe Id be better off trading it off for a truck that bonified to start with . I gave $2800 for the truck , put another $1000 in Tires , wheels , 02 sensors , wires , plugs , radial cable (which still didn't fix the horn , Airbag , cruise control problem) etc. Already in over my head .
    Since it wouldn't pass emissions , I registered out of the county I live in . I have been unemployed so I'm out of money and unless someone gives me what I have in it , I will drive it this way till I trade it in . Its on St. Louis Craigslist if anyone's interested . Thanks again for your help
  9. May 12, 2015 at 1:28 PM
    123DABTACOMA
    Dave
    Missouri
    3inch lift
    [​IMG] Well I bit the bullet and tore into my 1999 Tacoma . As suspected a burnt Exhaust valve on #1 cylinder. Now to order a Head Gasket Set .upload_2015-5-12_15-23-24.jpg Then to machine shop to have head and the rest of the valves checked . Need gasket kit before machine shop so valve guide seals can be installed with the valve
  10. Jun 8, 2015 at 12:56 PM
    123DABTACOMA
    Dave
    Missouri
    3inch lift
    Got my cylinder head back from the machine shop , put it back together and it purrs like a kitten . Checked my valve clearance while the head was off , was off some but went ahead and put it together . Apparently valve shims are a dealer item , and being the weekend was out of luck . Thanks you guys for the information
  11. Jun 8, 2015 at 1:05 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Based on my experience don't rebuild only the head, rebuild the whole engine while you have it apart, the bottom end will fail soon if you only do the head. Also, taking your parts to a good machine shop (if you see Ferrari engines and whatnot there you'll know it's good) will result in a much better engine than any rebuilt on an assembly line engine where no effort is made to keep the parts matched up.
  12. Jun 8, 2015 at 4:32 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    First try to adjust them and if that doesn't work, then start tearing into it. Start with the small easy things then move on to the more technical stuff.
