bad vibration 50 mph+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by celicamt, Nov 16, 2019.
  1. Nov 16, 2019 at 5:49 AM
    celicamt
    celicamt [OP] Member
    Matthew
    2013 Tacoma Sport Quad Cab
    Leveling kit
    I have a Bad vibration in my 13 Tacoma from 50mph and up. worse between 50 and 60 mph. Vibration is in the seat not in the steering so I am thinking it is something in the back of the vehicle. I had thought it was the tires so I replaced those, didnt change anything. drove it with the rear drive shaft off of it and it is still there. The vehicle does have a normal leveling kit on it but I dont think that would be it. I work at a Toyota dealer and am at the end of my rope with this.
  2. Nov 16, 2019 at 5:58 AM
    Shawn_of_the_dead
    Shawn_of_the_dead Well-Known Member
    Shawn
    Miami, FL
    2020 Cement SR5 DCSB
    Pop this bad boy in to counter act them bad vibrations.
    Sorry...could help myself.
  3. Nov 16, 2019 at 6:08 AM
    celicamt
    Matthew
    Leveling kit
    Hahaha good one!
  4. Nov 16, 2019 at 6:14 AM
    Gonzo1982
    Gonzo1982 Well-Known Member
    Tullahoma, TN
    2013 MG DCLB TRD Sport
    5100, OME 885, 1.5” Icon AAL, KO2 275/75/17
    Lifted?
  5. Nov 16, 2019 at 6:19 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Have you had the techs where you work look at it.
    SR-71A likes this.
  6. Nov 16, 2019 at 6:22 AM
    celicamt
    Matthew
    Leveling kit
    2" in the front one in the rear.. leveled.
    Yes I have had the techs here at the dealer look at it.. Stumped...
  7. Nov 16, 2019 at 6:25 AM
    Gonzo1982
    Tullahoma, TN
    Pinon Angle, Carrier Bearing Angle, drive shaft. Need to check all the angles. Could need carrier bearing drop, shims, etc.
    Blockhead likes this.
  8. Nov 16, 2019 at 6:27 AM
    Gonzo1982
    Tullahoma, TN
    Also have them check your rear brakes. They might need replacing or turned some. Make sure there isn’t tension on the e brake cable either from the lift.
  9. Nov 16, 2019 at 7:15 AM
    celicamt
    Matthew
    Leveling kit
    I took the rear drive shaft off and drove it in 4wd and the vibration is still there..
    also just had brake drums replaced and parking brake checked to make sure that all was good and it didn't change anything..
    Good thinking though. Thank you
  10. Nov 16, 2019 at 7:18 AM
    Gonzo1982
    Tullahoma, TN
    Assume your tires are balanced and in good shape?
  11. Nov 16, 2019 at 7:29 AM
    celicamt
    Matthew
    Leveling kit
    Yes. We had initially thought it was the tires and I replaced them with new. balanced and balanced them. Even had our balancer at the shop checked because we had thought that it could be off.
  12. Nov 16, 2019 at 7:31 AM
    Gonzo1982
    Tullahoma, TN
    Did it vibrate before the front and rear lift? Is the rear lift a block?
  13. Nov 16, 2019 at 8:01 AM
    celicamt
    Matthew
    Leveling kit
    It was years ago that I leveled the truck.. no it didnt do it then. this is a fairly new issue.. its just a 1inch block in the rear.. i have had the leveling kit on for years and it was fine.. Working at the dealer I see this trucks all the time totally beat and drive them with the same kits on and then are fine..
  14. Nov 16, 2019 at 9:44 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Did you take the complete rear shafts out with the carrier bearing?
    If only the rear portion and left the carrier in then you never eliminated that mess and/or mass of vibration - pretty common one.
    If it was totally out and the tires were road force balanced to rule out a bad tire, then check front wheel bearings, shocks, CVs (drivers is sloppy so look up ECGS and their bearing fix), alignment way off (4 wheel align), trans/xfer mount, steering rack, ball joints, rubber bushings, rear spring separating/failing if stock, and that's all I can come up with now to look at. You would hear the rear bearings and rear diff if they were failing. To rule out all things rear end jack stands under rear and run it up and see if anything shakes/hops back there to rule it out so you can more up front. Good hunting and it may take awhile to nail the source down.
    TACOGUY23 likes this.
  15. Nov 16, 2019 at 5:01 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    I understand what you have done with the tires but I still think that is the issue.
    Did you put four new ones or just rear. If rear only, swap the fronts in.
    Possible shocks but i still think tires.
  16. Nov 16, 2019 at 5:13 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Alignment?
    Was the truck ever wrecked? Frame bent? Etc?
    Bed loose?
    Is the driver seat bolted snugly?
  17. Nov 17, 2019 at 1:04 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Stock or aftermarket wheels?
  18. Nov 18, 2019 at 12:15 PM
    celicamt
    Matthew
    Leveling kit
    The tires are all new and it didn't change anything.. took all the tires/wheels off and had them road force balance to make sure that there was not a defect in a tire and there wasn't. Then took the wheels/tires off of another Tacoma on the lot and swapped them. didnt change anything.
  19. Nov 18, 2019 at 12:26 PM
    celicamt
    Matthew
    Leveling kit
    Truck was never in an accident and the alignment is good.
  20. Nov 20, 2019 at 9:12 AM
    Harsh
    Harsh Well-Known Member
    Norfolk, VA
    2014 White Tacoma TRD Sport
    I am in the same boat except that my truck (2014 TRD Sport double cab 2WD) is bone stock. I have new tires that have balanced a few times so I am confident they are not the issue. The only work that has been done was the dealership tried to fix the shudder under acceleration so it is possible they didn't assemble everything correctly.
    I have been reading this thread and plan on going through it this weekend to see if I can find anything.
    https://www.tacomaworld.com/threads/driveshaft-angles.465292/
