Bad Vibration at 5MPH
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sportsphreek, Feb 28, 2011.
  1. Feb 28, 2011 at 11:46 AM
    Sportsphreek
    Sportsphreek [OP] Active Member
    Virginia
    Double Cab TRD Off Road
    I have fought with Toyota and opened a case, but they still maintain this behavior is normal (It isn't).
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/132447-vibration-24-29-mph.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/136672-fixed-more-vibes-free.html
    I plan on realigning the carrier bearing and potentially dropping it 1/4"-1/2" (Seems a bit much for just the Rear Leaf TSB) but I did have a question.
    I do experience the take off shudder (Probably most likely ~5MPH) and the vibrations ~25, but at 5MPH the whole truck is practically bouncing up and down (Just coasting at 5MPH). ONLY at 5MPH (+/- 1MPH). The frequency is lower than the other vibrations - could this still be the carrier bearing and drive angle?
    Additionally, as a general question, why would the vibrations only appear at certain speeds? Simple harmonics blending into the rest of the car or something?
    Thanks,
    -SP
  2. Feb 28, 2011 at 12:43 PM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    i have some similar problems after adding my lift but i went and lowered my CB and i still feel the vibes at low speed and then again at 60 on the HWY but i really dont know what it could be. I have looked into everything.
  3. Jun 21, 2020 at 7:01 AM
    2ndgen4lyfe
    2ndgen4lyfe New Member
    05 Tacoma Trd Off-road
    A/T’s
    I just started experiencing this issue about a week ago. Took it to a mechanic who told me the tires were faulty. So I went to pep boys where I got my tires (cooper discoverer at3 with 8,000 miles on them). They proceed to tell me my suspension is shot and my tires are cupped causing the vibrations. $1,200 Of brand new suspension all around and new tires later and I’m still having the problem. There giving me some Falken wildpeak A/t3W’s because he said it could be the tire brand causing it. I then “had some words” (To put it nicely) with him before agreeing to take the wildpeaks. To be fair my OEM bilsteins were in rough shape but I Wish I would have known this is an issue.
  4. Jun 24, 2020 at 4:57 PM
    ahyoung
    ahyoung New Member
    I also have falken wildpeak A/T3W'S it vibrate early in the morning when the tires are cold, after a few miles the vibration goes away, and it drives great.
  5. Jun 24, 2020 at 8:40 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, many pinstripes.
    So... are those tires made from the same material as the Space Shuttle O-rings?
