bad wheel bearing??
Discussion in 'Suspension' started by gwiz11, Oct 18, 2013.
  1. Oct 18, 2013 at 11:13 AM
    gwiz11
    gwiz11 [OP] New Member
    vermont
    05 trd sport
    I have a 05 trd sport, just got it used with 84000 miles, I get the typical growling / humming noise that comes from a failed bearing when driving, however the noise and vibration goes away with 4x4 engaged, any ideas? I bought an extended service plan so I think its covered, but if its easy enough and cheap ill just do it myself just so I don't have it sit in the shop for however long.
  2. Oct 18, 2013 at 11:15 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    The bearings fail on these things frequently, so that'd be where I start. There are a couple people on here that have done a lot of the work for us and sell complete assembled bearings that make the job 100x easier to do on your own now, so that'd be the route I'd take.
  3. Oct 18, 2013 at 11:19 AM
    gwiz11
    vermont
    05 trd sport
    You got a link? I was told tacomas were bulletproof practically, starting to think not so much, what else should I expect to break?
  4. Oct 18, 2013 at 11:21 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
  5. Oct 18, 2013 at 1:13 PM
    PB65stang
    Patrick
    Kansas City
    The post above me has one of the links I was referring to. These are very, very well-made trucks, but like anything mechanical, they will break sometimes. The wheel bearings are a common issue (lost 1 @ about 40k miles, no issues with either since, and now I'm @ 120k). That being said, don't lose faith in the quality of your truck just yet.
  6. Oct 19, 2013 at 1:21 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    While wheel bearing failure is common, when a bearing type growl goes away in 4wd, look into this. Watch the vid.
    http://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing.html
  7. Oct 20, 2013 at 8:30 AM
    gwiz11
    vermont
    05 trd sport
    Took it to the dealership, they said driver side wheel bearing, noise goes away in 4hi, the tech showed me how rough the wheel was rolling when in the air, got an appointment tomorrow to have it replaced under warranty, hope its that.
  8. Oct 21, 2013 at 11:41 AM
    gwiz11
    vermont
    05 trd sport
    Think its the diff bearing, dealer put new wheel bearing, still have noise that goes away in 4, dealer says its the diff but said they are not equipped to do the work lol, got an appointment at ford, lol I know...ford, but they said they can fix my diff, if they can't do it under warranty,may do it myself, is the bushing job all that hard? Saw videos and seems simple.
  9. Oct 21, 2013 at 11:44 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    dont lose faith in your truck like said earlier its mechanical it will wear out eventually and these trucks are pretty bullet proof although small things do need to be replaced every now and then. im fortunate enough to have 160k miles on the truck and nothing has gone wrong,
  10. Oct 21, 2013 at 3:58 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    It is pretty simple. If you can r+r a CV shaft, you should have no trouble.
