bad whining noise when started cold
Discussion in '4 Cylinder' started by floger70, Dec 9, 2009.
  1. Dec 9, 2009 at 3:47 AM
    floger70
    floger70 [OP] Young Taco
    Brett
    Waverley, Nova Scotia
    2000 Taco, 4cyl, reg cab shorty.
    tundra front springs 3" lift chev half ton rear springs 3 inch lift magnaflow muffler cb 33" kuhmo mud terrains pioneer deck. bilstien 5100
    okay i've notice when i start my truck as it gets colder and colder out side there is a whining noise. sounds like power steering. i went out and started it this morning and it was really bad(its really cold) but it usually only lasts for a couple seconds, this time it lasted for like 20 seconds. the fluid in the power steering reservoir is right and i don't know what else this could be. just very annoying to hear that every time i start it in the morning when its cold out side
    its a 2000 2.7L 4x4
    any ideas?
    thanks
    brett
    JRUNT86 likes this.
  2. Dec 9, 2009 at 8:48 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    The strap is probably worn or needs to be binded more
  3. Dec 9, 2009 at 9:31 AM
    floger70
    Brett
    the strap? you mean the power steering belt? or.....
  4. Dec 9, 2009 at 2:40 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    does it sound like a S/C whine or more of a somethings broke whine?
  5. Dec 9, 2009 at 2:40 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    if it is..then its problly jsut teh belts need to be tightend up
  6. Dec 9, 2009 at 3:23 PM
    supralight
    Dan
    Earth
    Yes I meant the belt, sorry my english isn't perfect. If I remember well my underhood, you have only 1 belt for everything. Verify if the noise comes from there.
  7. Dec 9, 2009 at 6:33 PM
    floger70
    Brett
    okay. ill check tomorrow when i start it up first thing. im more used to the 22re motors but ill see whats up tomorrow. like i said its only when its really cold out.
  8. Dec 10, 2009 at 6:28 AM
    floger70
    Brett
    okay. it did it for a second this morning but its defiantly not the tension on the belt. all belts are tight and its not a squeal like a belt either. just sounds like the fluid is so cold and its not moving right away in the pump or something.
    also there's kind of a weird whistle or humming when i drive in 3rd gear at about 25 mph. but as soon as i speed up it goes away or change gears. it does it in other gears at different speeds to just dont know off hand what they are.
    any other ideas?
  9. Dec 10, 2009 at 10:40 AM
    Landon54
    Landon54 Canadian Eh
    Landon
    Marathon, Ontario
    K&N Air Filter, Grom Audio Ipod Interface, Tailgate Hose Clamps, Block Heater, Krown Rust Protection, 245/70/17 BFG AT's, Fog Light Mod, BHLM
    I just noticed this recently in my 07 as well. Mine only lasts as long as the key is turned over though. I haven't checked it out yet but it sounds like it's coming from the air intake side under the hood.
  10. Dec 10, 2009 at 12:34 PM
    floger70
    Brett
    yours sounds more like the starter wind. mine is more of a whining instead of a wind, lol i know hard to explain on here with no actual sounds. but i know what your talking about. mine sounds like a power steering pump with low or no fluid in it, i check and everything is tight and full of fluid to the proper level.
    im stuck
  11. Dec 17, 2009 at 3:58 AM
    glennleno1966
    glennleno1966 Member
    Mine does the same thing it usually does it within a minute of being started and usually as im turning but it only lasts for a brief second or two its comming from the back passenger side of the engine compartment
  12. Dec 17, 2009 at 5:36 AM
    floger70
    Brett
    yea and thats where the power steering pump it located. i noticed when i turn the wheel while its doing it it makes more noise then stops. it really sounds like its low on fluid but only for a second.
  13. Dec 23, 2009 at 6:13 PM
    Yota1
    Yota1 Well-Known Member
    my 2010 does this too, and it only has 1500 miles. Not sure what it is, it only does this a literally a second or 2 but only when cold, and about 2-3 seconds after start up
  14. Dec 23, 2009 at 6:25 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    abs. maybe. my 08 does it to i guess it doesnt bother me to much. if you find out let us know. it could be an easy fix
  15. Nov 30, 2010 at 1:17 AM
    djs1960
    djs1960 New Member
    06 tacoma access cab 4x4
    I have an 06 and it does the whining when its cold outside, last a minute or so,I checked ps fluid ,belt and pulleys everything seems ok
  16. Dec 4, 2010 at 4:38 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    The whining could quite possibly be the alternator charging at start up. I know at the shop that I work at we had a Buick come in with the same type of noise, and all it ended up being was the alternator...nothing wrong just charging. I'd leave it and see if it gets worse
  17. Dec 6, 2010 at 4:56 PM
    tacoriffic
    tacoriffic Well-Known Member
    Greg
    Rhode Island
    Clarion CX609 HU, Satoshi Grill, More to come
    I've had my '11 a week tomorrow and notice the slight whine. My father has the same issue in his '07. As the dealership would say "performing as designed".
  18. Dec 6, 2010 at 4:58 PM
    tacoriffic
    Greg
    Rhode Island
    It has been pretty cold in the north east lately.
  19. Dec 6, 2010 at 11:43 PM
    Vrbas
    Vrbas Well-Known Member
    Mine whines a little on a cold start with cold weather... but i think that "whine" is just the engine revving to about 1500 RPMs. I think the engine does this to pump up oil to the valves/valve springs and warm them up.
  20. Dec 7, 2010 at 11:25 AM
    perry709
    perry709 Member
    St. John's, NL
    2004 Tacoma SR5 V6 Offroad 4 door
    Toytec Ultimate Lift Kit with Dakar Leaf pack 265 70 17 MTZ's on VTec Wizard offroad rims ARB Front Bumper with KCHilites LED's and IPF Halogen's Rock Sliders, Color matched cap with Rack.
    I have the exact same problem, whining noise when I give it gas though! I gotta 03 Tacoma TRD OffRoad, sounds just like power steering pump but like OP said fluids are fine. I whel it pretty hard and just decided to chalk it up to age and beatings. If you find anything out let me know!
