bad whining noise when started cold
Discussion in '4 Cylinder' started by floger70, Dec 9, 2009.
  1. Jan 30, 2015 at 10:02 AM
    good vibes
    good vibes Well-Known Member
    mike
    NC
    2014 tacoma double cab
    3" lift 20" hostile rims toyo open countrt
    2013 Tacoma V6 cold engine sound: http://youtu.be/gNur_7zd6Ec. Is this normal some v6,s do this kinda pulsing whine while cold
  2. Jan 30, 2015 at 10:09 AM
    good vibes
    mike
    NC
  3. Jan 30, 2015 at 10:09 AM
    perry709
    perry709 Member
    St. John's, NL
    2004 Tacoma SR5 V6 Offroad 4 door
    Toytec Ultimate Lift Kit with Dakar Leaf pack 265 70 17 MTZ's on VTec Wizard offroad rims ARB Front Bumper with KCHilites LED's and IPF Halogen's Rock Sliders, Color matched cap with Rack.
    It was much much more then that, if I remember correctly I ended up replacing the 4x4 actuator and diff in the front end. I still got the truck and she still loves the beat downs, just not as often as before. Thanks man
  4. Jan 30, 2015 at 10:12 AM
    good vibes
    mike
    NC
  5. Mar 2, 2015 at 4:35 AM
    Tacomamba
    Tacomamba Well-Known Member
    albq
    2013 Baja Edition Black
    Supercharger Roof rack Tube step Entune Tailgate mod ATC Camper OE Skid Plate K/N filter don't need anything else
    Thanks for recording sound. I have taken mine to dealership and left it overnight and they claimed no problems. They claimed that because truck was new the Pistons were would flapper a little in sleeves. It did not make sense. My truck was too new to be left in dealer parking for 1 week while they did nothing so I have lived with sound till this morning when I woke to move truck in garage from outside and after starting my truck the noinoise from engine after cold start annoying me and then did this search. Please post any updates or fixes. It does not do it after warm up so by the time I am at dealership I cannot be there with them to experience cold start. I may use this recording on my next visit.
  6. Mar 2, 2015 at 11:01 AM
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    My 2006 2.7 base model does the same thing, after looking at it along with multiple of my buddy mechanics, and after reading it looks as if it just does it as part of the startup cycle while the engine gets to operating temperature. I remember it not doing it when i first bought my truck but hey, it has 89k miles on it
  7. Oct 28, 2016 at 7:57 PM
    zc00038
    zc00038 New Member
    Zachary
    Pennsylvania
    2012 Silver Tacoma PreRunner SR5 V6
    This is applicable to any Toyota/Lexus vehicle with a 4.0L V6 GR Motor, most common in Tacoma's, 4Runners, and FJ's, (although the engine layout is slightly different).
    So you start your truck cold and it makes a steady high pitch whining/whirling sound right after start up, but only for approximately 20 seconds, then stops, and it only does this only when the engine is cold. Does this sound like your problem? If so, here's the exact explanation of what's actually going on.
    These engines have a SMOG Secondary Air Injection Pump, located in the engine compartment on the passenger side (left) at the very top, along the side wall. It is before the Denso Fuel Injection Control Module, and after the Air Intake and Washer Fluid Reservoir. It is all black, and circular shaped. It has a single hose attached, which routes to a rail mounted to the top of the exhaust manifold, and a series of electrical wires, white, black, purple, and white/black stripe, which routes to the a part of the wiring harness running along the left wall. This component is what the sound emits from, and here's why it does this.
    In this component, there is an electric fan, which activates for approximately 20 seconds after the engine starts if it is well below operating temperature. The purpose of this fan is to force fresh air into the exhaust system (via the hose directly routing to the rail mounted to the exhaust manifold). This is done so the exhaust catalyst can lite much faster than if it was only igniting off of exhaust fumes. It only takes a few seconds to lite, and only really needs help when it's really cold.
    So I would not recommend tampering with this, and advise you to just let this component perform as designed by the manufacturer, as there is nothing wrong with it, and it is functioning as intended. I guess if it really bothers you, you could just unplug the connector powering the fan, but that might turn on the check engine light, possibly even throw a few fault codes. But honestly, why bother? Its a quick high pitch sound that lasts for only 20 seconds. Is it really that big of a deal?
    Lets put it this way. If I can put up with my wife whining 24/7, then you can put up with your Tacoma whining 20 seconds. I sure put up with both, at least the truck isn't as high maintenance as she is.
    By the way, I know this thread is way old, but I always wondered about this, and this is one of the places that I looked for the answer. So when I finally discovered it, I thought I would at least post it. (Brand new to the forum also:)
    zc
    Yapretzel, Yodeville and Jigeye like this.
  8. Nov 14, 2017 at 7:22 AM
    Nutzack510
    Nutzack510 New Member
    Zack
    02 crew
    So, had to create an account after seeing this... in my case, in my 3.4 I really get a nice long SPECIFICALLY power steering for sure, only when cold and sometimes worse if parked nose down, while I was in northern Washington when it was pretty damn cold in the morning it would wine for about 10 minutes pretty loudly and sounded like a Ford Explorer
    Bottom line, after engine warmed up it would be fine unless a harsh turning situation were to arise, then it would get a small whine flicker but go away right away. Have not really checked fluid, but I am considering doing a fluid change hopefully soon. Will let you guys know the results. I'm in the Bay Area now and it gets just cold enough for it to whine for a bit before warming up, soon to go back to Washington so I'd like to get it done before then. Any ideas before I get going? Anyone else have any luck doing the same? Or heard the same on their truck?
  9. Nov 14, 2017 at 7:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    You woke up a mummy thread from 2010............
    I'm just interested in seeing if any of the original players respond. :spy:
  10. Nov 14, 2017 at 3:09 PM
    Nutzack510
    Zack
    02 crew
    Google found it, I was trying to find out if anyone had found the issue for first gens but no luck so far. Damn it's that old? Haha
  11. Nov 24, 2017 at 4:34 PM
    iamroddy
    iamroddy Well-Known Member
    Hey, you never know...not the first time this thread has come back from the dead.
    I'll throw another possible cause into the ring...I have a cold start whine with my truck as well. It is a 2nd gen 2.7 automatic access cab 4X4. The power steering pump, lines and fluid are new. No whine there. The other morning was pretty brisk, so I started the truck and crawled underneath for a listen. The transmission pump whines a bit when cold, but not once warmed up. I wonder if it is a common trait and some people are just more sensitive to it.
  12. Jan 16, 2018 at 12:44 PM
    JRUNT86
    JRUNT86 New Member
    Jose
    2003 Tacoma SR5 4x4
    Draining and Cleaning the power steering reservoir helped my 2003 tacoma. I’m sure the stuff I used wasn’t safe but it worked. I disconnected the hose that returns to the power steering reservior and Then I ran the truck while adding transmission fluid to reservoir. I watched it on YouTube. It works. Next time I’m adding diesal to clean it better since it’s starting to make noises again.
  13. Jan 16, 2018 at 12:47 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Fan clutch.
