Badge removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jetmagnum, Oct 1, 2009.
  1. Oct 1, 2009 at 7:04 AM
    jetmagnum
    jetmagnum [OP] Well-Known Member
    NEW JERSEY
    09 TRD SPORT
    Is ther a sticky somewhere on a procedure to properly remove badges and trd decals on here somewhere? I did a search but it didnt bring up much.
    Thanks
  2. Oct 1, 2009 at 7:06 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
  3. Oct 1, 2009 at 8:41 AM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
  4. Oct 1, 2009 at 8:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Blow dryer, fishing line and patience!!!!:D
  5. Oct 1, 2009 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Also, I have found if you use a spray wax to keep the fishing line lubbed, it will cut thru the adheasive faster, and last a little longer.
  6. Oct 1, 2009 at 9:16 AM
    BSP4x4
    BSP4x4 Guest
    I just ripped mine off.....came right off! (i'm am however talking about the dealer badge)
  7. Oct 1, 2009 at 9:19 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    And you can use goof off to get the sticky stuff off your truck when done.
  8. Oct 1, 2009 at 10:21 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh good idea!!! Oh and I also used goo gone to get off all the excess from the rear TRD side panel decals.
  9. Oct 1, 2009 at 4:50 PM
    satchsd
    satchsd Old Guy Member
    keller texas
    i used fishing line but had to use 30 lbs test to keep it from breaking used a sawing mode
  10. Oct 1, 2009 at 6:24 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You said "lubed"...uh huh huh huh..huh huh
  11. Oct 1, 2009 at 6:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Only problem with the "ripping it off" with alot of badges is that they will chip the paint with the corners and edges.
    Concur with the fishing line and hairdryer trick. Chris's lube thing probably helps too...
  12. Oct 1, 2009 at 6:36 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    Braided fishing line works very well if you have some on hand. If not don't go purchasing it just for this because it's much more expensive then regular monofillament.
  13. Oct 1, 2009 at 6:37 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    i literally am loling
