Baja Designs - Plug and Play LED Fog Pocket Kit - 2nd Gen (05-11) + MORE !!!
Discussion in 'Lighting' started by Baja Designs, Apr 14, 2016.
  1. Apr 14, 2016 at 10:11 AM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Increase Safety and Awareness at Night with our Plug and Play Fog Pocket Kits!
    These kits are the perfect addition for someone looking for improved light output and performance while keeping the OEM fog location.
    07-13 Tundra / 05-11 Tacoma Fog Pocket Kit
    - Plug and Play Wiring Harness. Plugs directly into OEM Wiring and Utilizes factory Fog Light Switch.
    - Accepts Squadron Series LED Aux. Lights. Use Squadron-R for Amber Lighting
    - Black Powder Coat Finish
    - Fog Pocket Kit - $53.95
    Not sure what lights to get? Take a look at our compatible Squadron Series LED Aux. Lights!
    https://www.bajadesigns.com/Products/led-auxilary-lights.asp
    Squadron Sport, PAIR - $206.95
    3150 Lumens each - 20W/1.4A
    Squadron Pro, PAIR - $386.95
    4900 Lumens each - 40W/3.5A
    -Bailey, Baja Designs
    www.bajadesigns.com
    Enter BDForums coupon code for 10% OFF + $5 Shipping to the Lower 48! (pricing in red)
    tacowestley and DistortedAxis like this.
  2. Apr 14, 2016 at 10:13 AM
    Baja Designs
    San Marcos, CA
  3. Jun 22, 2016 at 9:04 AM
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
    Wow those light's are bright
  4. Jun 23, 2016 at 7:08 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    are these DOT?
  5. Jun 23, 2016 at 8:01 AM
    Baja Designs
    San Marcos, CA
    These are Not DOT approved. Unfortunately DOT approved lights greatly reduce the performance and output of these lights. These are designed for off road use with the Sport being a little more Street Friendly.
    It is up to driver discretion if they would like to use them on the street.
    Thank You,
    Bailey
  6. Sep 21, 2016 at 9:28 AM
    Baja Designs
    San Marcos, CA
    Thanks for all of the orders everyone! These 05-11 Fog Pocket Kits are taking off like our 12 + Kits!
  7. Nov 3, 2016 at 1:08 PM
    Baja Designs
    San Marcos, CA
    [​IMG]SCLBTACO by Baja Designs, on Flickr
    2011 4cyl 4x4 Tacoma out enjoying Anza Borrego with our Fog Pocket Kit! Get yours now!
    www.bajadesigns.com
    *NOTE: 05-11 Trucks w/o Factory Fogs can easily install this kit. Customer used the wiring included with Pair of Lights instead of fog pocket harness adapters.
    AxisCab likes this.
  8. Nov 12, 2016 at 7:39 PM
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Have any close ups of them installed on the truck?
  9. Mar 29, 2017 at 8:28 AM
    Baja Designs
    San Marcos, CA
    We are currently experiencing longer lead times than normal. Most orders are shipping in 3-4 business days unless otherwise noted.
    If you pay extra for NEXT, NEXT Day Saver, or Second Day shipping we will get your order out in 1 business day depending on when the order is placed.
    Please call (800)422-5292 to confirm lead times and product availability.
    Thank You!
    bailey@bajadesigns.com - www.bajadesigns.com - (800)422-5292x114
  10. Apr 5, 2017 at 3:22 PM
    davids540i
    davids540i Well-Known Member
    SoCal
    2010 MGM DCSB TRD Off-Road 4x4
    Does this kit allow for some slight up and down movement for alignment purposes?
    I'd want to make sure that both left and right sides are even and that I can direct them not to bounce off the ground too much and not to be too high towards on coming drivers.
  11. Apr 6, 2017 at 1:22 PM
    Baja Designs
    San Marcos, CA
    Quoted from General Discussion Thread:
    @Maximus
    Since I did not see very many pics of the fog light kit on an '05-'11 Tacoma, I'll contribute some of my own shots.
    I installed this kit yesterday- I have not been able to drive with them at night, yet but I did compare the BD Squadron Sport light to my stock fog light during the day. The BD are much brighter but not blinding.
    The brackets fit the fog light buckets well. In my pics, there is a small gap on top of the mounting bracket only because I have them aimed down.
    10/10, would buy again.
    AxisCab and davids540i like this.
  12. Apr 6, 2017 at 1:23 PM
    Baja Designs
    San Marcos, CA
    There is slight adjustment in the bracket. It's definitely minor but can be seen in the above photos
    davids540i[QUOTED] likes this.
  13. Jan 26, 2018 at 8:19 AM
    nameaneh
    nameaneh Active Member
    Eddie
    2014 White Tacoma TRD Off Road
    Sorry to rehash an older thread, but I'm looking at the Baja Designs Squadron Pro for my Tacoma to replace the factory fog. I can't decide if I should go with amber of just white. I like the white because I feel like I need the extra light when I drive at night, but the amber is nice for driving in snow here in Utah (at least I imagine it would be). Anyone have any thoughts?
  14. Jan 26, 2018 at 8:26 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    This is the reason I went with the Rigid Dually DOT. I can pop on an amber cover if I need it in inclement weather. Plus they're street legal and I won't get harassed by cops or my yearly inspection.
  15. Jan 26, 2018 at 8:28 AM
    nameaneh
    Eddie
    How do you like the Rigid's? Significantly brighter? I'm not old, but man I feel like I'm going blind at night and need all the light I can get (that won't blind others).
  16. Jan 26, 2018 at 8:28 AM
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    I run amber....if your gonna run them as fogs while on the street buy the sports not the pros. Even my sports are aimed all the way down to keep glare at a minimum.
  17. Jan 26, 2018 at 8:36 AM
    nameaneh
    Eddie
    Hey I’m originally from Richmond (Chester) too
  18. Jan 27, 2018 at 6:39 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    brighter than stock fogs? absolutely yes. VA is pretty strict on this stuff come inspection time....so this gives me peace of mind. I was already told by Toyota those wouldn't pass...the I told the dumbass in front of the entire waiting room to check the lights and they say SAE DOT. now give me my sticker!! lol
  19. Jan 27, 2018 at 6:04 PM
    Baja Designs
    San Marcos, CA
    No worries - thank you for posting up! I responded to your other post as well :)
    If you're planning on using the lights on the street with other traffic, I'd highly recommend considering the Sports as they are considered street-friendly when aimed correctly.
    If you do encounter poor conditions like snow the Amber will be beneficial in reducing glare.
    One of the great features about Baja Designs (BD) is the uService Technology. This will allow you to change from Amber to White or White to Amber, all you need is one of our replacement lens kits and 10-15 minutes of your time. https://www.bajadesigns.com/products/Replacement-Lenses.asp
    Let me know if you have any questions!
    www.bajadesigns.com
    el topu likes this.
  20. Jan 29, 2018 at 6:39 AM
    229tacoma
    229tacoma Well-Known Member
    Peter
    Tifton
    05 PreRunner DCSB
    dirty
    What do you recommend to install in aftermarket bumper? Calls for a 3.5" fog light I believe. Would like to be on-road friendly!
