baja warrior
Discussion in 'Suspension' started by carlos chavez, May 13, 2008.
  1. May 13, 2008 at 11:33 PM
    carlos chavez
    carlos chavez [OP] New Member
    05 PreRunner SR5
    3" Revteck lift All Pro upper control arm 17"Mickey Thompson's wheels 33" BFG KM2
    Has any of you tried King shocks on your Tacoma?, I have Revtek spacer and I want to upgrade to a real suspention system. Any help?
  2. May 15, 2008 at 9:41 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    The only Tacoma I've personally seen running King shocks had a Total Chaos long-travel setup.
    I heard 1 guy running the Kings with the stock control arms say the ride was overly stiff. Could have been incorrect valving or the wrong coils in his case.
  3. May 16, 2008 at 6:55 AM
    bigguy78619
    bigguy78619 Well-Known Member
    san diego, ca
    07 TRD Off-Road PreRunner DC
    my boy runs front king coilovers only, with stock control arms, and they seem to be good. A little stiffer than stock but its not really noticeable. I dont see a big difference from stock only that you get the cool look of "king" coilovers. Do you guys off-road a lot? If you are going to fork up some nice $$$ for a performance suspension try looking into other coilover setups also. People think king is the best out there just because a lot of people are running them in desert racing because thats what king shocks are designed for punishing terrains. Try Donahoe racing, sway-away, or even walker evans they have cool set ups not designed for racing because king or fox shock are valved for extreme offroading that most likely you wont do. Chances are you wont get those shocks hot enough to need kings! My 2 cents!
  4. May 16, 2008 at 7:05 AM
    mjp2
    NJ
    I will. :devil:
    I'll be running Fox 2.5" coilovers in the near future.
  5. May 16, 2008 at 7:48 AM
    bigguy78619
    san diego, ca
    MJP, after seeing you truck and how nicely done it is i know you will get those shock red hot!...nice prerunner
