Baka's 1998 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Taco No Baka, May 10, 2013.
  1. Nov 4, 2015 at 11:07 AM
    #221
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :eek: nooo!
  2. Nov 4, 2015 at 11:10 AM
    #222
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    At this point I'm taking donations towards the "Get the OGT Back On The Road Before The Annual Citrus Meet" fund. :anonymous:
    Rattletrap66[QUOTED] likes this.
  3. Nov 4, 2015 at 11:11 AM
    #223
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    we ought to do a car wash fund raiser at hooters :D
  4. Nov 4, 2015 at 11:13 AM
    #224
    Taco No Baka
    Lee
    Tampa, FL
    Or do that T-shirt drive thing. "Save the OGT" :cool:
  5. Nov 4, 2015 at 3:45 PM
    #225
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    That really sucks man.
  6. Nov 4, 2015 at 3:53 PM
    #226
    Taco No Baka
    Lee
    Tampa, FL
    QFT. I hate to think what's left to go Tango Uniform after I get that rather lengthy list of issues addressed. It has been kinda rough going into second since I put the locker in. I suppose I'm going to lose a synchro in the trans next and then it's pretty much game over for sure. :(
  7. Nov 4, 2015 at 4:33 PM
    #227
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Just keep driving it like me :D. My transmission has been real weird since I put my rear locker in too.
  8. Nov 4, 2015 at 4:38 PM
    #228
    Taco No Baka
    Lee
    Tampa, FL
    That was the plan. :D Unfortunately, she's decided she wants to be a lawn ornament instead, so she crapped a wheel bearing, one of the few things I won't defer for later and still keep driving her.
  9. Nov 4, 2015 at 4:56 PM
    #229
    allenfab
    Todd
    Lakeland, FL
    I feel you there. Wheels bearings are pretty important haha
  10. Nov 9, 2015 at 4:49 AM
    #230
    Taco No Baka
    Lee
    Tampa, FL
    Southern01Taco and allenfab like this.
  11. Nov 17, 2015 at 10:51 AM
    #231
    Taco No Baka
    Lee
    Tampa, FL
    Well, I have my wheel bearing and the seals are on the way. Just have to wait a little bit, probably after Thanksgiving, before I order my LCA bushings. Then it's just a matter of taking everything apart, having the machine shop press the new bearing and seals into the spindle, replacing the LCA bushings, and having it aligned. Easy peezy. o_O
    Just have to hope none of the eccentrics are frozen in the LCA bushings. That could get costly and :frusty:. I'm hopeful though. When I had it aligned after the lift 2 years ago, the tech didn't say anything about any frozen eccentrics and I've already splooged them down with Acetone/ATF a week or so ago and I plan to do it again a day or so before attempting to remove them.
  12. Nov 25, 2015 at 1:26 PM
    #232
    Taco No Baka
    Lee
    Tampa, FL
  13. Jan 5, 2016 at 5:34 PM
    #233
    Taco No Baka
    Lee
    Tampa, FL
    Got some new parts today. Got my Timkin carrier bearing and a set of Centric Stop-Tec braided stainless steel brake lines for my front brakes. The brake lines look like some really high quality parts and they came with all new hardware (banjo bolts, crush washers clips, and even plugs for the hard lines and calipers so you don't leak all your fluid out while installing them). Damn impressive considering they only cost about $36 at Rockauto.
    I also replaced my lower ball joint-to-spindle bolts with a set of Dorman 10.9 class M10 x 1.25 x 35mm flange head bolts. The factory bolts and the new ones that came with the ball joint were dubiously short. They never failed, but I was never comfortable with the depth of engagement on the outboard bolts which were 8.8 class M10 x 1.25 x 30mm and had a lockwasher under the head to boot. I'm a lot more comfortable with these. I left the lockwashers out, but I always use locktite on these bolts anyway.
    Still waiting on the new tie rod end to replace the one I bent at Hardrock back in December. I'm kinda chomping at the bit to get the OGT back on her wheels.
  14. Jan 21, 2016 at 10:14 AM
    #234
    Taco No Baka
    Lee
    Tampa, FL
  15. Jan 21, 2016 at 10:16 AM
    #235
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  16. Jan 21, 2016 at 10:17 AM
    #236
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Glad your getting the OGT all fixed up. I know it sucks but better to find this stuff at home than on the trail.
  17. Jan 21, 2016 at 10:23 AM
    #237
    Taco No Baka
    Lee
    Tampa, FL
    I'm hoping this is why my brand new tie rod went Tango Uniform after one trip to Ocala. If not, I'm going to have a switch to something more expensive, lifetime warranty or not. :frusty:
    SpruceTaco[QUOTED] likes this.
  18. Jan 21, 2016 at 10:26 AM
    #238
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    With the play in the rack guide it's a good possibility it caused to failure in the tie rod.
  19. Feb 25, 2016 at 6:06 AM
    #239
    Taco No Baka
    Lee
    Tampa, FL
    New goodies for the OGT. :cool:
    Missing from the display are the hi-lift mounts and my paranoid (tm) switch panel.
    THROTTLE231, allenfab and SpruceTaco like this.
  20. Apr 13, 2016 at 9:51 AM
    #240
    nkeene
    nkeene Well-Known Member
    Nick
    Oviedo
