Baka's 1998 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Taco No Baka, May 10, 2013.
  1. Jun 4, 2013 at 8:48 PM
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves, 33x13.50 Super Swamper LTBs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, Lincoln Locked front diff, Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 20" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods.
    :goingcrazy::facepalm::lalala:
    :rofl:
  2. Jun 4, 2013 at 8:56 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Its ok dirtydtaco debadged and painted his emblems and put the 5 on sr5 on upside down :rolleyes: dont tell him i told you this :spy:
  3. Jun 4, 2013 at 9:30 PM
    Taco No Baka
    Lee
    Tampa, FL
    Haha, I bet he was definitely like :facepalm:
    Anyhoo, I'm pretty sure I got them close enough that you'd actually have to measure them to detect any unevenness. They didn't pull down flush with the roof quite as much as I would have liked, but that's what the rubber pad underneath them is for.
    Now I just have to figure out where I'm gonna put my CB radio. I have a '90s era Cobra 25 LTD Classic that's been tuned up and had a roger beep installed, but unfortunately it has the side mounted mic jack. If I got a single DIN stereo I could maybe get away with mounting it in the dash under the stereo like I've seen some folks do, but other than right on top of the dash, I really don't see anywhere else to put it.
  4. Jul 21, 2013 at 2:21 PM
    Taco No Baka
    Lee
    Tampa, FL
    The F250 is sold! Finally! Now that that's done, I pulled the trigger on my 4xI Sliders, Complete OME 3 inch lift with Dakar rears from Toytec, and some bed rail caps. Next on the list is taking the Taco to be painted. This build is finally going to start moving! I'm thrilled!
    :rockband::taco::yay::yay::goingcrazy::goingcrazy:
  5. Jul 21, 2013 at 4:29 PM
    2010TRD
    2010TRD Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    Sweet .. Can't wait for your return to the pits
  6. Jul 21, 2013 at 6:37 PM
    Taco No Baka
    Lee
    Tampa, FL
    No doubt! Of course, it'll be like I showed up in a whole new truck. :cool:
  7. Jul 22, 2013 at 9:11 AM
    2010TRD
    Thomas
    Waldo, FL
    Any new tires coming with this lift ?
  8. Jul 22, 2013 at 9:13 AM
    2010TRD
    Thomas
    Waldo, FL
    So it said sr2 ?
    :rofl:
  9. Jul 22, 2013 at 9:53 AM
    Taco No Baka
    Lee
    Tampa, FL
    The tires and wheels I plan on getting at the 4wheelParts around the corner from my house.
    Here's the plan...
    Pro Comp Series 97 Flat Black 15x8 steel wheels with a 3.75 Backspacing
    33x12.50 R15 Bias Ply TSL Super Swampers (I'd really like to have the SX's but they only come in 33x14 R15, which I'm afraid would be too wide to fit.)
    :cool:
    On the downside, the new paint isn't looking too good. The color change may exceed my budget and I'm not sure I want to pay a grand to get it repainted a color I don't particularly like (at least it's not red though). I have one more place to check. If he's not inside my acceptable limits, then I may just decide that the crappy paint is just a reason not to feel too bad if I scrape it on a rock or tree or something.:(
  10. Jul 22, 2013 at 3:35 PM
    2010TRD
    Thomas
    Waldo, FL
    I say as long as there's no rust, then why repaint it
    Look at the interco M16 mudradials.. They are considerably quieter smoother and wear better
    That's if your going the swamper route
  11. Jul 22, 2013 at 8:15 PM
    Taco No Baka
    Lee
    Tampa, FL
    Quieter is not really a factor for me. I like the noise. The M16s are okay, I guess, but their a little too much of an AT for me. I pretty much know what I'm getting into with the bias ply tires. They tend to flat-spot when parked for a while and it takes a little warming up before they get round again. And then there's the infamous Swamper wear factor. I don't put a lot of miles on my truck so even with swampers, I'm more concerned with how long they can go before rotting than how many miles I can get out of them, especially on a truck as light as a 1st Gen Taco. Had a set of 33x12.50 Trxus M/Ts on the F250 (which tipped the scales at 7500 lbs) and while it was a close thing, they weren't down to the wear bars before they rotted and started chunking after 9 years.
    Anyway, I did consider a set of 33x12.50 SSRs, but they are almost a full inch shorter than the 33x12.50 Bias Plies in addition to being about $25 more a pop. However...since you mentioned it and I went and looked it up, I did see something I hadn't considered. The LTB. I can get those in 33x13.50 R15 and they are only a buck more a tire than the TSLs. The question will be: can I clear the extra inch in width?
    I think I'll give them a shot. They almost have sidewalls like the TSL-SXs so they are probably pretty tough in the rocks.
  12. Jul 23, 2013 at 3:23 AM
    2010TRD
    Thomas
    Waldo, FL
    All very good points
    Sounds like you have done your homework
  13. Jul 23, 2013 at 4:02 AM
    Taco No Baka
    Lee
    Tampa, FL
    I've had Swampers, Boggers, and Trxus M/Ts before so I kinda know what to expect. ;)
    I'm just hoping I can fit those 33x13.50 LTBs on 8" wheels with 3.75 backspacing and still clear the UCA without having to run spacers or SpiderTrax. I don't mind doing some fender clearancing if I have to. I got a sawzall and a ziz wheel and while reluctant, I'm not afraid to use them, lol.
  14. Jul 23, 2013 at 2:30 PM
    2010TRD
    Thomas
    Waldo, FL
    That rim tire combo fits 2nd Gen without spacers
    But I have no experience with 1st Gen
    You may try sending a pm to local FL member "Goomba" (josh)
    He has alot of experience with 1st Gen ;)
  15. Jul 23, 2013 at 3:03 PM
    #35
    Taco No Baka
    Lee
    Tampa, FL
    Please note, it's a 33x13.50. ;) So that said...you know someone that runs 13.50s on a 2nd Gen? If so, that's cool. Probably means there's a good chance of it working with a 1st gen too. I honestly think it'll be a wash as far as clearance on anything but the UCA. The normal TSL 33x12.50 says it's 33.7" OD while the LTB is only 32.8" OD, but is about .6" wider in cross section than the TSL (tread width is 1 inch wider). Of course, this is all math. Reality may prove to be radically different. :eek:
    Thanks for the tip about Goomba though.:thumbsup:
  16. Jul 23, 2013 at 4:05 PM
    #36
    2010TRD
    Thomas
    Waldo, FL
    Yeah .. I thought it was 12.50 wide .. I personally had m16 at 12.50 on OEM rims
    13+ would be tight on uca with 2nd Gen
  17. Jul 24, 2013 at 3:09 AM
    #37
    Taco No Baka
    Lee
    Tampa, FL
    Rgr that. Not sure what the backspacing is on the OEM 16x8s (I'm thinking like 4.25" for some reason). On my 1st Gen, the 31x10.50s are fairly close to the UCA on the factory 15x6 wheels, which probably doesn't bode well since there can't be much more than 3" of BS on a 6" wide wheel.
    I'm hoping if anything I could get away with .25" spacers because, unfortunately, the lock-outs are really short and I'm afraid using those 1.25" SpiderTrax things may end up with the lock-out being recessed inside the hub of the wheel (which would probably make them even more difficult to operate).
    Anyway, hopefully the tire shop will trial fit one beforehand so if it doesn't clear the UCA I can go to the regular TSLs.
  18. Jul 24, 2013 at 12:52 PM
    #38
    Taco No Baka
    Lee
    Tampa, FL
    Update on the paint...
    I'm having it shot with flat OD green. Should look pretty good with all the chrome blacked out.
  19. Jul 26, 2013 at 10:02 AM
    #39
    Taco No Baka
    Lee
    Tampa, FL
    A very nice man showed up with this today...
    THROTTLE231 likes this.
  20. Jul 26, 2013 at 5:19 PM
    #40
    2010TRD
    Thomas
    Waldo, FL
    Those leafs look nice :thumbsup:
