Ball Joint Boot HELP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jayandcourt, Sep 29, 2010.
  1. Sep 29, 2010 at 7:50 PM
    jayandcourt
    jayandcourt [OP] Active Member
    Oklahoma
    05 DC TRD Offroad
    Weather tech mats, removed mud flaps, ARE camper shell Billy 5100 set at 1.75 Toytec AAL 2" Grillcraft grill and TRD symbol Hella lights behind grill Yakima Rack Procomp 7089 Grom Iphone interface Avid bolt on sliders
    Just recently had 5100's put on front and went to have my oil changed and they said my lower ball joint boot had been pushed up. It's not leaking, but I need to pull it back down in place anyone have any ideas, even if possible. The dealer told me that I had to older an entire new uppercontrol arm assembly kit for over $400.00. I said are you kidding, for a $3 dollar boot. So PLEASE help me, the boot is not torn, justpushed up. Thanks to all, and to all a good night!
  2. Sep 29, 2010 at 7:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Can you post a pic?
  3. Sep 29, 2010 at 8:06 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I can't see why you'd need an entire UCA assembly. So long as you haven't squished all the grease out of there.
    And even then...why in the hell can't they just take a syringe of grease and relube the fucker.
  4. Sep 29, 2010 at 8:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cant see why a UCA would fix a LOWER ball joint....:confused:
  5. Sep 30, 2010 at 12:47 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    It wouldn't - someone f'ked up.
    The lower boot is not available as a separate part, so you must buy the ball joint. The ball joint is not available as a separate part, so you have the buy the whole LOWER control arm assembly.
    I would either try to get the boot back into the proper position, or continue to monitor and fill with grease when needed. i did this for over two years on my '98 Tacoma and the joint still hadn't developed play...
