Quick Links: Pin out for AC power switch 3RZFE engine Spark Plugs & Coil Wires (question about which specs are important) Aluminum coolant overflow tank... Whos swapped out the plastic one? Hard shifting in A340 after transgo kit and rebuild Transmission and Differential fluid change on 140k Front, rear diff and T-case fluid change
Ball Joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by tryin2buildit, Dec 6, 2013.
