BamaToy's Garage and Diagnostic Center.
Discussion in 'Technical Chat' started by BamaToy1997, Oct 24, 2013.
  1. Nov 8, 2015 at 10:07 AM
    #121
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    2015
    TRD OR
    Looking to upgrade electrical. Buying a new high amperage alternator. I know you sell the ones in your group buy so I know you'll know this off the top of your head. What is the crankshaft diameter? Stock everything under hood. Thanks in advance. Searched threads and all I could find is talk about supercharger pulley diameters.
  2. Nov 8, 2015 at 1:50 PM
    #122
    BamaToy1997
    BamaToy1997 [OP] Wheel Bearing Master
    Bill
    Navarre, FL
    Are you wanting the actual diameter of the crankshaft at the pulley, or the stock pulley diameter?
  3. Nov 8, 2015 at 2:34 PM
    #123
    gibby11
    Andrew
    Las Vegas, NV
    Crankshaft at the pulley por favor. The stock pulley is 3.00" correct?
  4. Nov 8, 2015 at 3:19 PM
    #124
    BamaToy1997
    Bill
    Navarre, FL
    I don't know the measurements where the pulley itself rides. I looked up some information and one spec is crank pin diameter, which I think is what you are looking for, and that is 2.086", but I am not sure if that is the diameter at the pulley. The stock pulley though is actually a little over 7 1/2 inches in diameter.
  5. Nov 8, 2015 at 3:59 PM
    #125
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    I'm having the exact same issue. Spent this weekend trying to locate the source with no luck. It happens when I press the brake pedal, it sounds like something is getting shifted and knocking into something when I hit the brakes. I jacked up the front end and spun the drivers side tire by hand then pressed the brake pedal with my hand while standing outside the truck and I heard it, definitely something occurring while hitting the brakes. I'm at a loss
  6. Nov 8, 2015 at 4:01 PM
    #126
    BamaToy1997
    Bill
    Navarre, FL
    Remove the wheels in the front, check your backing plate behind the rotor, and check your caliper. Two good places to start.
  7. Nov 8, 2015 at 4:05 PM
    #127
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Thanks Bama, yeah I removed both front wheels and everything appears normal and tight. It's got me puzzled brother.
  8. Nov 8, 2015 at 4:11 PM
    #128
    BamaToy1997
    Bill
    Navarre, FL
    Check the CV axle where it enters the back of the spindle assembly to see if there is play in it. Also inspect the inner seal at that same location. Check for scoring or any possible contact.
  9. Nov 8, 2015 at 4:20 PM
    #129
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Will do. That is one place I didn't check. Thanks
  10. Nov 9, 2015 at 9:26 AM
    #130
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    What about your brake hardware? Your sliding pins? You can pull them out and remove the brake dust and then regrease them. I've had that issue before. Could also be bushing being worn our on your LCA or loose shock mounts.
  11. Nov 9, 2015 at 12:03 PM
    #131
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Bill, I wanted to add another symptom. The noise doesn't seem to appear if I stop and leave the truck on, for example when I went to a Wendy's and parked to eat I left the truck running in park and ate and when I took off no noise. I then drive to my destination and shut truck off and run into store for maybe 5 minutes go and start truck and the noise appears. Again just once and then I drive and don't hear noise until next time I go to use truck. Why I'm so confused is it gives a strong suspicion of brakes but what would brakes have to do with the truck being left on or not. Tia
  12. Nov 9, 2015 at 12:16 PM
    #132
    BamaToy1997
    Bill
    Navarre, FL
    Only thought there is heat saturation.
  13. Nov 9, 2015 at 6:06 PM
    #133
    Beerline123
    I'm sorry but could you elaborate on what heat saturation means. I tried to look it up but couldn't find a relation to automobiles. Tia
  14. Nov 9, 2015 at 6:17 PM
    #134
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
  15. Nov 9, 2015 at 6:21 PM
    #135
    BamaToy1997
    Bill
    Navarre, FL
    Heat saturation is when you have something like the brakes for example that naturally get hot over use. When you are driving and use the brakes, heat is generated in the rotor, caliper, and pads. Normal driving helps cool these components as air crosses over them. But when you get them hot and then stop, and don't drive to cool them, the heat actually will transfer deeper into the component. This deeper penetration of heat can cause thermal expansion which can "shift" components a small amount. This will vary depending on the amount of time between parking and resuming travel. It's not a very common problem, but it has been known to happen. Just one option for the reason behind why it does it most of the time, but not in the short time you go into a store and back out.
  16. Nov 9, 2015 at 6:37 PM
    #136
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Year: 2011
    Make: Tacoma
    Model: Off-Road
    Engine size: V6
    On top of this basic information it would be VERY helpful to include:
    Is a lift installed: Yes, Icon C/O's in front, Icon shocks in rear, Dakar Leaf pack with AAL.
    Aftermarket components: Quite a few. A full list (well mostly full list) can be found here https://www.tacomaworld.com/threads/velillens-2011-ac-m-t-build.386364/ Since that thread ive also done the fog light anytime mod and locker anytime mod...both of those within the last week though
    Is there an alarm system installed: No
    When did you first notice the problem?: Probably around 6 months ago
    How often does it occur?: Every single startup
    What have you ALREADY replaced to try and fix it?: I disconnected the battery and let it sit for ~30 minutes then reconnected it. Still got the error. Ive inspected the ABS sensor wires the best i could
    Have you checked codes?:My ultragauge2 shows no error codes
    Ok now for the actual problem! Whenever i turn the truck on two lights come on and stay on. Light number one is just the letters ABS on the right side of the cluster (upper right). The other is what i believe is called the "Slip Indicator" icon. Its the Car with swearing tire tracks behind it with a yellow background in the left cluster on the bottom.
    I had installed the lift and had no error's. Then one day (dont remember exactly when) these two lights came on. My little bit of research indicates its probably an ABS issue. But Im not even sure where to begin or even if its something i can try to fix or need the dealer to fix. The couple other threads ive found mention having the VSC zero'd and if they are able ot zero then its all good but if they get an error there is a problem with one of the sensors.
    Thanks for any help! Just hoping i can help save money having the dealership diagnose this
  17. Nov 9, 2015 at 8:20 PM
    #137
    BamaToy1997
    Bill
    Navarre, FL
    The best I could suggest you do is go to a parts store and see if they have an ABS code reader. The simple code reader you have most likely is not a body code reader, but just an engine/transmission code reader. There will be some kind of code stored if your ABS and TRAC lights are on. We have to get that done first.
  18. Nov 10, 2015 at 4:27 AM
    #138
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ill stop by the auto zone on my way home from and have them hook it up to check for codes.
  19. Nov 10, 2015 at 4:19 PM
    #139
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Just stopped by both AutoZone and orielys. AutoZone the guy doesn't think their scanner reads abs codes. Hooked it up and no codes. Went to orielys and the guy had zero clue and basically just handed me the scanner and said bring it back in when done. Hooked it up and turned truck on same way as at AutoZone with no codes. Sadly I forgot to get the models of the scanners to check what all they read.
    The AutoZone guy did say right off the bat I'll more than likely have to take it to the dealer or a Toyota specific place vs being able to do anything myself
  20. Nov 10, 2015 at 4:56 PM
    #140
    BamaToy1997
    Bill
    Navarre, FL
    Any auto shop worth it's weight in salt should have a scanner available to check. Many will do it as a courtesy. That is the best suggestion I can give at the moment.
