BamaToy's Garage and Diagnostic Center.
Discussion in 'Technical Chat' started by BamaToy1997, Oct 24, 2013.
  1. Nov 10, 2015 at 6:32 PM
    #141
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ill try to give that a shot tomorrow. Sadly Im not a fan of the two near me so Ill have to try to get time to go to my normal shop.
    Course my Tacoma still has a couple recall things ot take care of so wouldnt be a bad idea to just go to the dealership either at this point.
    Thanks for the suggestions at least! If i get a code or anything ill be sure to post
  2. Nov 10, 2015 at 7:03 PM
    #142
    BamaToy1997
    BamaToy1997 [OP] Wheel Bearing Master
    Bill
    Navarre, FL
  3. Nov 11, 2015 at 11:20 AM
    #143
    Don A
    Don A Active Member
    Don
    Barcelona Red SR5 4x4 Access Cab
    Hi Bill,
    I have been referred to you by a fellow TWer and i am hoping that you can help ...
  4. Nov 11, 2015 at 1:06 PM
    #144
    BamaToy1997
    Bill
    Navarre, FL
    Reading your description, and what the tech has done in trying to find the issue, I would initially be inclined to check the steering rack and pinion mounting bushings, bolts, and tie rods. That would be my initial thought. Is the click sound just a single "click" or is it more of a "click-click-click-click"?
  5. Nov 11, 2015 at 3:20 PM
    #145
    Don A
    Don A Active Member
    Don
    Hi Bill,
    I was out doing errands and i found a quiet parkade to try different scenarios ... turning left and right ... going back and forth ... to find more info.
    The 'click' is usually singular but every once in awhile there will be two clicks in fairly rapid succession. The clicks vary in loudness but are audible at low speed (5 mph or less) with the windows down.
    I had a friend outside the truck listen as i went back and forth left and right sometimes with the hood up and he thought that the click was coming from the central engine bay.
    I thought that i heard the same click a couple of times as i shifted in or out of a gear (automatic tranny).
    Maybe i am starting to imagine things.
    The aforementioned friend is much more mechanically inclined than i am so i will ask him to help me check the steering rack and tie rods.
    The dealer mechanic has been spending a lot of time under my truck lately so i would hope that he would have looked at these items ... but this is the same guy that has guessed wrong as to a fix three times in a row. Best i double check!
    Thanks,
    I will let you know what we find ... or don't find.
  6. Nov 16, 2015 at 6:42 AM
    #146
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Bama,
    I'm to fixing to replace my rear wheel bearing, i was wondering if you could help me out with the part numbers for the inner sleeve, o ring, c-clip, metal washer, and inner wheel seal on the diff. I plan on doing both sides just to be sure. I might make a write up or video as well to help the rest of TW do this.
    Also, is there any way to add extra grease to the wheel bearing itself?
    I appreciate the help!
  7. Nov 16, 2015 at 9:01 AM
    #147
    BamaToy1997
    Bill
    Navarre, FL
    I don't have a parts list for the rear. I am willing to bet if you called your local Toyota dealer they would give you part numbers and prices and then you can search for them to get the best deals. Right now Rockauto.com has the best prices for the bearings themselves. Just be sure to get Timken/Koyo
  8. Nov 16, 2015 at 9:02 AM
    #148
    BamaToy1997
    Bill
    Navarre, FL
    Good suggestions right there. Have you been off-roading lately, or had heavy rain?
  9. Nov 16, 2015 at 3:22 PM
    #149
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Hey Bill, just want to thank you for the help troubleshooting my alternator problem. The 250 amp alternator works great. It was an easy change out. Better alternator, I can feel the weight difference between yours and oem part. Truck is running so much smoother also. Great deal, thank you!!
    BamaToy1997[OP] likes this.
  10. Nov 17, 2015 at 8:59 AM
    #150
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Year: 2001
    Make: Toyota
    Model: Tacoma prerunner
    Engine size: 3.4L
    Is a lift installed: Icon coilovers, Icon AAL and Icon 2.0 rear shocks
    Aftermarket components: just suspension
    Is there an alarm system installed: Viper 1 way
    When did you first notice the problem?: slowly gotten worse over the past few months
    How often does it occur?: All the time
    What have you ALREADY replaced to try and fix it?: rack bushings
    Have you checked codes?: N/A
    Mileage: 103k
    Ok so long story short, I have play in my steering. I didn't really do any diag as to what was causing it, but I've seen many guys on here fix loose steering with new rack bushings so I replaced them with the poly ones from Wheelers. Still loose. I took the truck to work and got it up in the air and did a little shake down on the front end. Tie rods are tight, inner and outer. Rack bushings are solid obviously. Everything seemed tight so I had a coworker hop in the truck and wiggle the steering wheel a little, the steering shaft going into the rack will move a bit without any input being directed to the tie rods. This results in about a full inch of play in the steering wheel. One of the techs from my shop said I can adjust the pinion gear preload/ backlash, another said I should replace the rack. I've got no problem replacing the rack if need be, but if it just needs adjustment obviously thats what i'll do. I'm fairly new into the industry and would appreciate the input from a master tech. Thanks!
  11. Nov 17, 2015 at 9:35 AM
    #151
    BamaToy1997
    Bill
    Navarre, FL
    With play like the kind you are describing, there is not much you can "adjust" out. You can adjust the tension a little bit, which results in a stiffer feeling steering wheel, but excessive play like that I would be looking at the connection between the rack, and where the shaft connects. See that there isn't something loose there. (between the firewall and the rack itself) and also look under the dash to be sure that there is not something loose there either. If all of that is good, then the next step would be to replace the rack and pinion unit. You can find some at Advance Auto I believe that have the rack with tie rods and all in one sale.
  12. Nov 17, 2015 at 4:16 PM
    #152
    BamaToy1997
    Bill
    Navarre, FL
    No, it does not "sense" serpentine belt not connected. The odds are you either had bad connection at the battery, the battery is bad, or a bad connection at the starter or engine ground. (Of course it COULD be a bad starter, but let's leave the expensive checking for later. lol)
    DoorDing likes this.
  13. Nov 17, 2015 at 11:02 PM
    #153
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea the shaft itself is all tight, it's where it goes into the rack. The steering damper that sits right on top of the rack moves with the steering wheel, but that movement isn't transmitted to the tie rods. I'm pretty sure the excess play is within the rack itself.
    Should I get a reman rack or try to get a new one? Do you know of any "heavy duty" options or just the basic ones?
  14. Nov 18, 2015 at 2:01 PM
    #154
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Hey Bama, I'm back!
    Year:
    2008
    Make: Tacoma
    Model: SR5
    Engine size: V6
    On top of this basic information it would be VERY helpful to include:
    Is a lift installed: Yes, Extended Icon C/O's & Camburg Ball Joint UCA's in front, Bilstien shocks & Dakar Leaf pack in the rear.
    Aftermarket components: My Build Thread pretty much tells all: https://www.tacomaworld.com/threads/theostacos-2008-dcsb-build.325965/
    Is there an alarm system installed: No
    When did you first notice the problem?: After installing the ECGS Bearing & new Hub Assemblies
    What is the problem and How often does it occur?: Every time I'm driving and turn my wheel left and especially to the Right I'm feeling a vibration that appears to be coming from the front Diff.
    What have you ALREADY replaced to try and fix it?: I installed the ECGS Bearing, replaced both CV Axles with CVJ remanned CV Axles with high angle inner boots, replaced both Hub Assemblies.
    Have you checked codes?: Nope
  15. Nov 18, 2015 at 3:42 PM
    #155
    BamaToy1997
    Bill
    Navarre, FL
    So there is no vibration when going straight? Only when turning left or right, but more sever to the right? Couple of questions:
    1. Do you have wheel spacers installed?
    2. Did you get an alignment done after the lift components were installed, and if so, do you have a copy of the final results of the settings?
    3. Have you inspected the tires for possible "bubbles" or bad spots?
  16. Nov 18, 2015 at 3:55 PM
    #156
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    1. Yes, I have what appears to be "1/4 Inch" crappy wheel spacers on the front.
    2. Yes, I had an alignment done after the suspension components were installed. Not after we put in the cv axles, hub assemblies, & ecgs bearing.
    3. No, I have not inspected the tires for possible "bubbles" or bad spots or taken the truck into a tire shop to have them do so.
    I recently purchased 2 quarts of Lucus 85W-140 Non Synthetic Gear Oil and plan on draining the 75W-90 out of the front Diff and putting in the Lucus. ECGS recommends doing this. http://eastcoastgearsupply.com/files/PDF%20Files/toyota-clamshell-bushing-faq.pdf3
  17. Nov 20, 2015 at 5:49 PM
    #157
    Don A
    Don A Active Member
    Don
  18. Nov 20, 2015 at 5:54 PM
    #158
    BamaToy1997
    Bill
    Navarre, FL
    Whats up? Did you get the other things checked out?
  19. Nov 20, 2015 at 5:58 PM
    #159
    Don A
    Don A Active Member
    Don
    Hi Bill,
    Latest update ... the dealer had their 'head' mechanic look at my truck. He was unable to determine what was causing the 'click' noise.
    He did manage to find a torn ball joint boot ... probably torn by the first mechanic with a screwdriver or pry bar checking for play. I requested that he check the power steering rack mounting bolts and tie rod ends. Nothing found.
    I am at a loss as to what to do.
    I will pick up my truck from the dealer on Monday after i go in to have a discussion with the service manager and look for a good independent mechanic.
    Any more ideas of what to look for?
  20. Nov 20, 2015 at 6:01 PM
    #160
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Year: 2001
    Make: Tacoma
    Model: SR5
    Engine size: V6
    Issue: Truck ran great for a long time. Was diagnosing an oil leak on a JEG's filter relocation kit (very small leak) in my garage. Started the engine and was about to check through the wheel well and one of the hoses on the kit blew out, spraying oil everywhere. I shut off the truck immediately and got some new steal braided hose. Fixed the kit over the week, refilled the oil, installed a brand new filter and restarted the truck.
    Symptoms:
    -Oil light is on and won't turn off.
    -Truck is running a little rough.
    Did I blow the oil pump?
