BAMF 1st Gen rear shock relocation kit
Discussion in 'Bay Area Metal Fabrication' started by JLee, Nov 15, 2013.
  1. Jun 30, 2014 at 9:41 AM
    #61
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    don't think it really matters how much lift (or no lift) you have. Just need to get shocks that are the right length for your application. Pretty sure you need to get new shocks if you get this kit regardless.
  2. Jun 30, 2014 at 10:06 PM
    #62
    PNW
    PNW Active Member
    Nick
    Cle Elum, WA
    2000 4x4 TRD SR5
    Full OME lift kit!
    I was just curious if 12s were perfect for around a 3" lift like what I have.
  3. Jul 1, 2014 at 4:57 AM
    #63
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    It depends on a lot of factors, not just how much lift. The only real way to tell is cycle your leaf pack and measure.
  4. Jul 1, 2014 at 7:23 AM
    #64
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    This ^ lift doesn't matter you can fit 12's on a 6" lift mounted like ll and on a 3" they will be /\. This is a custom set up so your springs and shock placement are going to determine on what length your shocks are.
  5. Jul 3, 2014 at 6:37 PM
    #65
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Well I just got my kings on finally! Very happy with everything. One thing I will say is the head of the shock is so big on my kings that if I didn't get the 1.5" bushing size I don't think they would have fit as nicely. They might hit/rub on the relocation kit if you get 1.25" bushing size w/ kings (not sure about other brand shocks).. Also Jerry you might want to give longer bolts if they get 1.5" kits because the threads on my bolts didn't even make it to the plastic part of the nut. Anyways here are the pics:
    Then I stacked all the bricks I had to test the flex out a little haha
  6. Oct 20, 2014 at 11:38 PM
    #66
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Is there an alternate install/weld/angle to allow retention of the spare tire? Not looking to go all out travel, just want to give my rear shocks adjust-ability (mount outer to inner per dampening goals) if not a bit more travel while at it.
  7. Oct 21, 2014 at 6:20 AM
    #67
    JLee
    Jerry
    Grass valley CA
    No you would lose travel mounting the cross member like that. The spare tire needs to be removed for this kit to fit.
  8. Nov 25, 2014 at 11:27 PM
    #68
    BamaToy1997
    Bill
    Navarre, FL
    Jerry, I have had no luck finding where I thought I had paid for all of the things I wanted. Is there a way I can still get the original low price on the 1st gen relocation kit? As I recall they originally were around $180 on the first group?
  9. Nov 26, 2014 at 6:21 AM
    #69
    JLee
    Jerry
    Grass valley CA
    With the Thanksgiving sale they are less then that eight now.
  10. Nov 26, 2014 at 10:15 AM
    #70
    BamaToy1997
    Bill
    Navarre, FL
    :yay:
    ORDERED!!
    Date Ordered: 11/26/2014 Order Number:: AB-1991
  11. Nov 26, 2014 at 3:32 PM
    #71
    JLee
    Jerry
    Grass valley CA
    Got it this time.
  12. Dec 13, 2014 at 2:12 PM
    #72
    BamaToy1997
    Bill
    Navarre, FL
    Got my kit in. I didn't realize I was going to have to weld it together tho. Hahaha. And good pics of all the parts so I know how everything should line up before I hook up my MIG?
  13. Dec 15, 2014 at 5:48 PM
    #73
    JLee
    Jerry
    Grass valley CA
    Yeah it is a DIY kit so welding is involved. I dont have any colse ups of them welded up. The best way to do it is mount your shocks in the brackets and tack them up then fully weld your brackets before you weld them on thw truck.
  14. May 22, 2015 at 11:58 PM
    #74
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    12"? How does it ride ?
  15. May 26, 2015 at 11:18 AM
    #75
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Running 13" shocks under my bed ;) your kit looks badass guys
  16. Jul 29, 2015 at 12:13 PM
    #76
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    What are the extra holes for on the cross member? It looks like maybe 3 extra holes on each side. Is that to run shorter shocks like say 9" or 10"?
  17. Jul 29, 2015 at 12:15 PM
    #77
    JLee
    Jerry
    Grass valley CA
    Different angles
  18. Jul 29, 2015 at 3:12 PM
    #78
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Thanks dude.
    Any idea what length shock would work if I use the outer holes on the upper bracket? I'm going with an ADS shock in the rear.
  19. Jul 29, 2015 at 3:17 PM
    #79
    JLee
    Jerry
    Grass valley CA
    Nope It all depends on your set up. The best thing is to measure at full bump then go from there.
  20. Jul 29, 2015 at 3:22 PM
    #80
    presto
    Topher
    san francisco
    2000 T4R 4x4
    X2 mostly depends on what leaf pack your running... I have dakars and from what I remember when I was taking measurements a 12" shock worked on the inner two holes and a 10" shock worked for the outter two holes.
    Measuring/flexing is the most sure way to do it.
