BAMF IFS skids
Discussion in 'Bay Area Metal Fabrication' started by JLee, Aug 12, 2015.
  1. Apr 19, 2016 at 4:22 PM
    #181
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Once I have them on the site I'll be posting here first so I'm sure you will get one of the first. I'm running a 5'x10' sheet of each skid at the least as soon as I confirm that no changes need to be made to my prototype.
    NotRed[QUOTED] likes this.
  2. Apr 19, 2016 at 4:43 PM
    #182
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Can we get a look at the design or prototypes, build the hype beast...
    BudMan and TACOVRD like this.
  3. Apr 19, 2016 at 6:21 PM
    #183
    JLee
    Jerry
    Benicia, CA
    I might post one on Thursday :spy:
    itaro, tacomgee and TACOVRD like this.
  4. Apr 19, 2016 at 6:22 PM
    #184
    NateMob
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    :ohsnap: Awesome!
  5. Apr 19, 2016 at 7:05 PM
    #185
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    In for the mid and transfer skids!!
    Cant wait to see em!
  6. Apr 19, 2016 at 7:12 PM
    #186
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
  7. Apr 19, 2016 at 8:06 PM
    #187
    Fight4Function
    Fight4Function Slightly Mutant
    G
    SF Bay Area
    2014 DC TRD OR
    Looks awesome
  8. Apr 19, 2016 at 10:16 PM
    #188
    NotRed
    NotRed Well-Known Member
    I will be picking up both as well! :woot:
  9. Apr 20, 2016 at 8:22 PM
    #189
    NotRed
    Well, some of us don't like LOTS of ground clearance but take the necessary precautionary measures instead :thumbsup:
  10. Apr 21, 2016 at 7:46 PM
    #190
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    :popcorn:
  11. Apr 21, 2016 at 9:47 PM
    #191
    JLee
    Jerry
    Benicia, CA
    Oh that's right it's Thursday!
  12. Apr 21, 2016 at 10:00 PM
    #192
    NotRed
    added benefit - looks like the improved under chassis aerodynamics will result in an additional 4-5 mpg! :anonymous:
  13. Apr 21, 2016 at 10:04 PM
    #193
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
  14. Apr 21, 2016 at 10:28 PM
    #194
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    Sigh... Soooo much money spent recently, but I'll def be ordering these as soon as they come out.
    @JLee do you think my slightly wide blem IFS will line up bolt holes with your new trans skid?
    opteron likes this.
  15. Apr 21, 2016 at 10:45 PM
    #195
    JLee
    Jerry
    Benicia, CA
    Yeah I'm pretty sure it should fit up the holes are in the same location.
    BudMan[QUOTED] likes this.
  16. Apr 21, 2016 at 10:55 PM
    #196
    BudMan
    Bret
    06 TRD Sport DC 4x4
    stuff
    Thanks. Finger on the trigger...
  17. Apr 22, 2016 at 10:22 AM
    #197
    JLee
    Jerry
    Benicia, CA
    OP updated with links to the mid and trans skid I'll be burning out some this afternoon we just need .250 wall square tube to complete the trans skids so about one to two weeks lead time on the first run.
    opteron likes this.
  18. Apr 22, 2016 at 11:36 AM
    #198
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    I know I sound like a broken record, ahmmmm 1st gen..... :lalala:
  19. Apr 22, 2016 at 11:50 AM
    #199
    JLee
    Jerry
    Benicia, CA
    I'll tell you what if you can get 20 confirmed people to place a pre order I'll build 1st Gen skids. 1st Gen parts just don't sell as much as the new trucks so I don't want to waste a week designing something that's not going to pay out when we are busy enough as it is.
    opteron[QUOTED] and NotRed like this.
  20. Apr 25, 2016 at 11:52 AM
    #200
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Compatible with the URD Y-pipe?
