BANG! Trigger pulled on OME setup
Discussion in 'Suspension' started by TeamLombardo, Jul 2, 2012.
  1. Jul 2, 2012 at 11:07 AM
    TeamLombardo
    TeamLombardo [OP] WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    I finally decided on what I want to go with for a suspension setup for my 2012 TRD 4x4 DCSB. Ordered from Toytec 7/3/2012 using discount code. Please chime in.
    -OME 886 coils
    -OME 90000 sport front shocks
    -OME N182 rear shocks
    -Dakar leaf pack w/bushings and U-bolts
    -CB drop kit
    -3 degree shims w/hardware
    -LR UCAs
    -Stainless Steel rear brake lines
    Man I can't wait for it to arrive! Gonna attempt installing w/a buddy. I have a rusty screwdriver, some leftover model airplane glue, Bob the Builder hammer (for the tough jobs), and duct tape. I think I got it covered pretty well, so install should be a cinch.
  2. Jul 2, 2012 at 11:11 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You won't have any problems running the stock wheels and tires
    You will probably get more like 3 1/4" with the top plate spacers
    Get centre pin collars and add them to the Dakars before you install in case you need to use axle shims later
    Extended brake lines aren't a must , but are a good idea if you are going to flex it out a lot
  3. Jul 2, 2012 at 11:14 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Stock tires and wheels will most definitely not be an issue with the OME lift (or really any lift for that matter).
    Rear brake lines will be a bit tight at flex. It would certainly not be a bad investment, although there are plenty of people here that run this setup without extended lines. :p Including me (but they are on my list). I guess it would depend on how hard you intend to use this setup.
  4. Jul 2, 2012 at 11:27 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Nice set up you're going to like it.
    Don't waste your time or money on the diff drop (search 2nd Gen diff drop).
    You're going to want bigger tires. At least 265/75/16s (31.65").
    Yes stock will work, but look too small.
    Mine with 3" OME lift (885s & Dakars) in commuter mode (30.47" stock Dungflops)
    And in off road mode (33.3" 255/85/16 BFG KM2s)
  5. Jul 2, 2012 at 11:42 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Welcome to OME. You'll enjoy your stay
  6. Jul 2, 2012 at 12:37 PM
    TeamLombardo
    Tony
    El Paso
    Thank for the advice on the centre pin collars.
    So don't go with spacers? I plan on off-roading a bit and have read that spacers are a bad idea. Also, I am considering 886 coils because I intend on going with a Demello Bumper and winch, but not for a while tho. What are your thoughts?
  7. Jul 2, 2012 at 12:38 PM
    TeamLombardo
    Tony
    El Paso
    Thanks for the pics
  8. Jul 2, 2012 at 1:03 PM
    OZ-T
    Peter North
    British Columbia
    For a DC , I would probably get the 886's if I was going to add a steel front bumper and winch
  9. Jul 2, 2012 at 1:23 PM
    TeamLombardo
    Tony
    El Paso
    Just sent you a PM. Hope you don't mind
  10. Jul 2, 2012 at 2:09 PM
    penguins_cc
    Will
    Bellevue, WA
    I have a DCLB with 886s. I have not yet got my bumper and winch. However I do have front ATO skid plate and sliders. The ride does not seem overly harsh and I would make the same decision again instead of getting 885s now and waiting until bumper/winch to upgrade.
  11. Jul 2, 2012 at 7:39 PM
    TeamLombardo
    Tony
    El Paso
    Does your front sit higher than the rear with the 886 coils? You running dakars in the rear?
  12. Jul 2, 2012 at 8:18 PM
    OZ-T
    Peter North
    British Columbia
    Sent you one back
  13. Jul 2, 2012 at 9:55 PM
    penguins_cc
    Will
    Bellevue, WA
    PMed you back as well :eek:
    My front does not sit higher than the rear. I have about the same amount of rake as Oz. Affirmative about the Dakars in the rear. Love how those ride.
