Bank 1 02 sensor change.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mytacoma01, Jun 12, 2015.
  1. Jun 12, 2015 at 12:49 PM
    Mytacoma01
    Mytacoma01 [OP] Well-Known Member
    Bob
    Hendersonville NC
    2014 charcoal gray SR5 double cab.
    Hello all, I am about to change my bank 1 02 sensor and I read all the threads I could find on the forum, but I didn't find a tutorial on the job. My trans is automatic and I'm not clear as to how to take that shift knob off to remove the console, or more importantly, what I might screw up if I don't do it right. Any pearls of wisdom on this job would be greatly appreciated.
  2. Jun 14, 2015 at 2:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I don`t have a automatic so I guessing you need to have access from the top to release the harness so you can unplug the O2 sensor.
    I have always been able to unplug mine from underneath.
    More problems with the rusted nuts and broken studs.
  3. Jun 15, 2015 at 1:31 PM
    53rdcard
    53rdcard Well-Known Member
    2004 Black Tacoma SR5 4x4 3.4v6
    i recently did this very same repair, not even 3 weeks ago, i used this
    http://www.lieblweb.com/o2replacement.html
    and this video, now i think the video shows a automatic, the how to above shows a manual, i had the manual so i had to follow the above to get to the plug and the video to replace the sensor. one tip i learned was, you have to remove the sensor to get the slack to get to the plug on a manual
  4. Jun 15, 2015 at 6:55 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    You can do it from underneath the truck. Thats how I did mine. Pretty simple. Can be a little difficult if you have big hands like me though.
  5. Jun 18, 2015 at 3:45 AM
    Mytacoma01
    Bob
    Hendersonville NC
    Thanks to all of you for your help. That's exactly what I was in need of, both technical and moral support. :)
  6. Jun 18, 2015 at 9:13 AM
    Stone Cold ET
    Stone Cold ET Well-Known Member
    Adam
    Louisiana
    2003 DCSB TRD PRERUNNER
    Did mine a month or so ago (auto). I was able to get to it from under the truck pretty easily. Use whatever your favorite penetrating solvent is on the nuts and let it sit for a couple hours before you go at it. Mine came off with minimal effort after I hit them with PB a couple times over the course of a couple hours. Pick up some new nuts because yours will be shot more than likely (mine literally crumbled).image.jpg
  7. Jun 18, 2015 at 9:51 AM
    Mytacoma01
    Bob
    Hendersonville NC
    Thanks Adam. I appreciate the info. By the way what size replacement nuts should I get?
  8. Jun 18, 2015 at 10:53 AM
    Stone Cold ET
    Adam
    Louisiana
    Pretty sure it's 8mm x 1.25. I picked up some stainless steel ones from the local hardware store with some lock washers. I think it ended up being a 13mm wrench to put the new ones on.
  9. Jun 18, 2015 at 11:03 AM
    Stone Cold ET
    Adam
    Louisiana
  10. Jun 25, 2015 at 8:48 AM
    Mytacoma01
    Bob
    Hendersonville NC
    Heard about the denso sensor from other folks as well. That's what I got. :)
  11. Jun 25, 2015 at 8:59 AM
    53rdcard
    that is the one i got, just fyi autozone wants $50 more for that same part
