Quick Links: Shifter boot Bad fuel economy, knocking like crazy in first gear at WOT? Front wheel bearing/hub replacement diy with individual parts Manual trans grind after replacing oil/fluid Engine wire harness help -due to rats Front differential oil - does it need to be changed as frequently as the rear?
Barcelona Red Pop & Lock Installed (Pic)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeardedWeirdo, Feb 23, 2010.
