Base 2WD Mud Flaps....IMPOSSIBLE to find!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kilokato, Feb 18, 2012.
  1. Feb 18, 2012 at 7:07 AM
    Kilokato
    Kilokato [OP] Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    Does anybody know of any Front Mud flaps/guards that will fit a 2010 Base Access Cab 2WD? Non- Prerunner. I know the flaps for a 4WD are everywhere, but I can only find ill fitting, generic, drill your own holes, front flaps from people like Huskey. Has anybody found any decent ones that bolt on rather easy? I don't mind a little alterations but I want them to look good too...Thanks!
  2. Sep 17, 2012 at 12:29 PM
    pilotgalen
    pilotgalen New Member
    Tacoma SR5
    trailer hitch
    Unless you have fender flares, you are out of luck.:( Toyota does not even carry them.
  3. Feb 15, 2013 at 7:34 PM
    AdrenlineJunky
    AdrenlineJunky Active Member
    north
    013 2WD ACCESS 2.7 auto
    wtf? Has anyone tried to put the flare style ones over base fenders?
  4. Feb 15, 2013 at 7:53 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    05Taco4x4 and desertrunner24 like this.
  5. Feb 21, 2013 at 8:03 AM
    AdrenlineJunky
    north
    Not many answers I'm afraid. Looks like a pair of generic std flat flaps mounted to same holes in fender that the inner fender is secured to.....will have to be the answer.
    No biggie, just trim flap around the protruding "box" in fender inner.
  6. Mar 12, 2013 at 8:06 AM
    AdrenlineJunky
    north
    $25. No drilling. No paint damage. I got the guards at autozone.
    05Taco4x4 likes this.
  7. Mar 24, 2013 at 10:16 AM
    Columbian Taco
    Columbian Taco Member
    Columbia
    2012 Tacoma 2wd Base 5Lug
    1" rear drop. Currently sits 34.5" in the front and 35.0" in the rear.
    Good deal. I might have to do that soon.
  8. Feb 21, 2016 at 9:21 PM
    AftkmktHeadache
    AftkmktHeadache New Member
    2013 Toyota Tacoma 2WD 2.7L Base model
    AdrenlineJunky,
    Do you have the make and part # of any of the stuff you used to do this ?
    How did you get the old fender well rivets out ? Did you have to destroy them ? Did the fall down into the body on the inside ?
    What is the part # of the replacement push-type rivets you used with the wood screw ? Where did you get them ?
    How did you mark you holes to drill through the mudflaps ?
    What is the make and part # of the mud flaps that you used ?
    Have they held up well ?
  9. Jul 17, 2016 at 10:13 PM
    PyroTaco
    PyroTaco Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    Aftkmktheadache,
    I ended up using roadsport 4754 "b" series flap found on Amazon for $8.99. As for the clips, I used the stock ones on the truck. It's a super tight fit. As for a pattern, i used legal size paper, put it up against the the inside of the fender liner, found each of the clips, and poked a hole through the paper at the center of each. After that, I transferred the pattern over to the flaps then trimmed the flaps to fit around the box. Use a box cutter to cut through the flap with ease.
    -PyroTaco
  10. Jul 18, 2016 at 6:41 AM
    AftkmktHeadache
    ABA180 likes this.
  11. Jul 18, 2016 at 7:34 AM
    PyroTaco
    2013 Reg Cab Tacoma
    Ah you were asking adrenaline junky. I just stumbled across this post and figured I'd reply since it wasn't replied to for some time. Just trying to help a brother out with my findings and projects I've completed.
    -PyroTaco
  12. Jun 3, 2018 at 11:10 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    did you have much of an issue using the factory push plugs? Really want to slap on some flaps lol
  13. Jun 4, 2018 at 5:54 AM
    PyroTaco
    2013 Reg Cab Tacoma
    Nope no problems at all. Just took some pressing. However, I eventually replaced them with aftermarket plug as I had a few give up the ghost on me the last few years.
  14. Jun 4, 2018 at 10:32 AM
    Newfiebruh
    Tom
    Just picked up a set and gonna give it a go! What size holes did you drill into the flap? and did you trim for the black box or did you also attach the flap to the black box?
  15. Jun 4, 2018 at 11:39 AM
    PyroTaco
    2013 Reg Cab Tacoma
    I trimmed the flap around the black box and left the box in place. As for hole size, I don’t recall.
  16. Jun 4, 2018 at 11:46 AM
    Newfiebruh
    Tom
    Thanks. How did you get the fender liner rivets off? I almost bent my fender trying to take it off and ripped the flat part off lol. I know you have to depress two spots but how?
  17. Jun 4, 2018 at 2:03 PM
    PyroTaco
    2013 Reg Cab Tacoma
