Based on these measurements, are new uca’s needed?
Discussion in 'Suspension' started by Buckaroo1993, Oct 8, 2017.
  1. Oct 9, 2017 at 10:37 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    1.5-2* is more than enough and can be easily done on stock UCA's.
  2. Oct 9, 2017 at 10:38 AM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    With a 3”+ lift?
  3. Oct 9, 2017 at 11:00 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I'm running 3 and 3.4 castor with TC UCA's. I also paid for the lifetime ($250 or so) but have also got 6-7 alignments out of it. They also took my ask for more castor. So far it's more than made up for the cost. 3" lift will benefit nice with the UCA. You may be able to get bye but your truck will thank you.
  4. Oct 9, 2017 at 1:18 PM
    JayRolla
    Colorado Springs
    Yes with 3" lift. You lose about 2* caster. With stock suspension you can get 3.5*. Take off 2* and you can still get 1.5*. Stock UCA's give you the most clearance at the firewall and cab mount. People will complain of more rubbing once they go with aftermarket UCA's because they do fix the caster but at a cost of moving the tire towards the firewall and cab mount. I have fine tuned my SPC's to give me 2* caster but most firewall clearance because my cam bolts on the LCA's are fully maxed.
  5. Oct 9, 2017 at 2:52 PM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    If you say so but I haven't seen it done too well with any other truck including my own. But if it works it works! Less to buy!
  6. Oct 9, 2017 at 3:31 PM
    Buckaroo1993
    Vinny
    Georgia
    And WHAT is eating up my spring? Is it caused by the alignment issue?
    99B14284-2B99-40F2-8CB5-08D99233554A.jpg F682A27A-F08A-48F0-9130-CD2BB8455E23.jpg
  7. Oct 9, 2017 at 3:37 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Looks like it’s contacting the spindle at full droop.
    You can rotate the coil so at full droop the spindle pokes in between the coils instead of hitting them. Its probably going to take some muscle.
  8. Oct 9, 2017 at 3:44 PM
    Buckaroo1993
    Vinny
    Georgia
    There is NO WAY that spring will spin. Not even if I jack the truck up to let it go to full droop. Still too much pressure.
  9. Oct 9, 2017 at 3:51 PM
    Justinlhc
    It might require spring compressors than.
  10. Oct 9, 2017 at 4:11 PM
    Buckaroo1993
    Vinny
    Georgia
    I'm really second guessing myself on this lift thing. I should just go all the way back to stock.
  11. Oct 9, 2017 at 4:28 PM
    Buckaroo1993
    Vinny
    Georgia
    Can I just grind off that corner from the spindle? The odds of me rotating that coil without completely disassembling everything is slim to none plus what are the odds of finding rotating that spring to the e.x.a.c.t. open spot that corner intersects that spring at full droop? AND if its doing it turning left, straight or turning right.
    o_O
  12. Oct 9, 2017 at 5:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Even more reason to get those UCAs lol. Yeah man just grind that fucker smooth.
    JayRolla likes this.
  13. Oct 9, 2017 at 5:23 PM
    Buckaroo1993
    Vinny
    Georgia
    Hmmm...not sure how to take your statement. Ok to round off that corner or not?
    I agree on the UCA's.
  14. Oct 9, 2017 at 5:41 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah I meant should be fine to round the corner off. I'm kinda surprised that's what is contacting the spring, or did that just happen when your spring came off the coil isolator at the top? That was you that that happened to right?
  15. Oct 9, 2017 at 5:50 PM
    #35
    Buckaroo1993
    Vinny
    Georgia
    Yeah but we disassembled everything and rotated the spring around. While there are other areas debrided from the coil when the it came off the top isolator, that area is new.
  16. Oct 9, 2017 at 5:57 PM
    #36
    Buckaroo1993
    Vinny
    Georgia
    I just ordered SPC UCA's PN 25460. Hopefully they will help.
  17. Oct 10, 2017 at 1:49 PM
    #37
    Buckaroo1993
    Vinny
    Georgia
    Ok. I took it back to Firestone and they had their "Master Tech" work on it. The numbers are now as follows:
    Left Camber: -0.2* (was 0.5*)
    Right Camber: -0.4* (was 0.4*)
    Left Caster: 1.4* (was -0.1*)
    Right Caster: 1.1* (was 0.2*)
    Total Toe: 0.05* (was 0.05*)
    What are your thoughts?
    BTW, the top of the steering knuckle is still bumping/rubbing my NEW coil springs! Will a LR SPC UCA fix that?
  18. Oct 10, 2017 at 3:14 PM
    #38
    Buckaroo1993
    Vinny
    Georgia
    D31AC623-7479-4877-ACE6-244631BF9214.jpg Take a look at this pic. Notice the Camber on both sides and the arrows. Why do both sides say Neg camber but the left side arrow is pointing to the positive side of the line?
  19. Oct 10, 2017 at 3:14 PM
    #39
    Justinlhc
    Much better alignment this time which proves the original tech saying “caster is maxed” was bullshit.:smack: They could have got more caster if they hadn’t have brought the camber into the negative, but that’s as good as it gets with stock uppers.
    LR should fix your rubbing issues. It might take some adjusting and obviously you’ll need yet another alignment.
  20. Oct 10, 2017 at 3:22 PM
    #40
    Justinlhc
    That area is “spec”. I’m just assuming the middle of the spec area is -0.1°. The right side reads from left to right, negative to positive. The left side reads from right to left negative to positive.
    Not sure if I explained that clearly, but it all looks fine to me.
