Basic Recovery Methods?
Discussion in 'Off-Roading & Trails' started by dysfunctnlretard, Jul 24, 2009.
  1. Jul 24, 2009 at 7:03 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    I was riding a dirt trail the other day when I stumbled upon a group of dumb teenagers who thought there Geo Metro was a good off road vehicle. They ended up stuck but, being the newbie that I am, I had no tow straps or anything to help them out. I drove away thinking, "Even if I did have some, what the hell do I do with them???" So my question is, whats proper procedue for pulling out a stuck vehicle. Do I always need shackles? What basic gear do I need? Can I attach tow straps to the tow hitch? Does the puller always need the tie up in the rear and the one being pulled always in the front? Any help is appreciated?
  2. Jul 24, 2009 at 11:10 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    A 2"x30' recovery strap is a necessity. Along with 2 to 3 3/4" shackles. The tow hitch is a fine place to pull from.
    A couple of quick recovery pointers.
    - Always try to pull in a forward gear, avoid pulling from reverse
    - Never attach to anything that isn't the frame of the disabled vehicle (you don't want to be ripping off bumpers)
    - Even if you think you've pulled them out of the "stuck", pull just a bit further if the land permits to be sure.
  3. Jul 25, 2009 at 4:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Every situation is different and you gotta use some common sense & 'thinking' to know what's best & safe for each situation.
    Generally, look for tow points or tie-downs. If it doesn't have any - you want to find areas that are solid - like the frame. If the vehicle doesn't have a frame (Unibody), then structures in & around the axles, lower control arms, etc. Wrap straps around a 'larger' area versus around one small area (hard to explain).
    And of course, you ALWAYS want to make sure the owners of the stuck vehicle are aware.....anything can happen and its NOT your responsibility if something breaks (good idea to have a witness also). If they are not happy with that - then you need to walk away.
  4. Jul 25, 2009 at 7:43 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    And take care not to get yourself stuck too. Those 30ft straps look pretty long until you're trying to hook up to someone in the middle of a mud hole. I had to winch out last weekend and 100ft of winch cable was just enough to get me out of the mud and on solid ground, but barely.
